| Rear brake disc bolts http://ducatipaso.org/forum/viewtopic.php?f=3&t=6649 |
| Author: | angelix [ Mon Apr 07, 2014 3:02 pm ] |
| Post subject: | Rear brake disc bolts |
I am refurbishing a set of wheels which is missing the disc bolts at the REAR I tried ordering them through the Ducati dealer but I am told the code has been discontinued and that there is no replacement; most of the times part numbers are are replaced by other s used in different models, apparently this would be one of the odd cases where there is no replacement. I am thinking that maybe the ST2 ones are the same (maybe longer?), does anyone know? |
| Author: | Derek [ Mon Apr 07, 2014 6:30 pm ] |
| Post subject: | Re: Rear brake disc bolts |
The disc retaining bolts on most Ducatis are the same, usually M8 x 20 with a low profile hex socket head. |
| Author: | Crumpati [ Mon Apr 07, 2014 8:00 pm ] |
Which would be available at any Fastener supplier, probably a lot cheaper than any Ducati supplier!
| Author: | angelix [ Tue Apr 08, 2014 11:03 am ] |
Actually you would be very much surprised... the ST2 rear brake disc bolts are priced around 0.75GBP (1.25$) from the local ducati dealer. Sometimes it is worth giving them a call to find out, certain parts are veryy expensive, others are surprinsingly cheap. |
