| New Owner http://ducatipaso.org/forum/viewtopic.php?f=3&t=6654 |
| Author: | Uwe [ Wed Apr 09, 2014 4:45 pm ] |
| Post subject: | New Owner |
Hello I am new in this forum Drive past few decades Ducatis and I have now bought a 907ie. The motorcycle comes from a collection unfortunately some things had not been seen. Service Jam, no timing belt change, damaged rear swing arm caused by incorrect installation of the spacer sleeve. On both side panels are missing the retaining plug to the tank. For this, a question for you Is there a repair solution for the side panels.? regards Uwe |
| Author: | Mc tool [ Wed Apr 09, 2014 7:57 pm ] |
| Post subject: | Re: New Owner |
Hi Uwe , welcome to the mad house . I have seen side panels on e bay , which probly would have to include a paint job . If you have the broken off bits a good polyester glue should stick em back on .
| Author: | Bock900r [ Thu Apr 10, 2014 12:41 am ] |
Welcome Uwe, whitch part of Germany are you living? Regards RĂ¼diger |
| Author: | Uwe [ Thu Apr 10, 2014 5:04 am ] |
Hi RĂ¼diger Hessen northeast,near from Fulda. Regards Uwe |
| Author: | Uwe [ Thu Apr 10, 2014 5:09 am ] |
Hi Mr.Tool There are no plug and gums as a model on motorcycle Regards Uwe |
| Author: | Mc tool [ Thu Apr 10, 2014 6:11 am ] |
" and today's cryptic X word clue is ................. Then I would investigate fitting some well nuts to the tank and drilling 6mm holes where pins used to be and use some 6mm fairing screws to attach side panel , gee ! if you did it right it would probly look "factory " Hamish
| Author: | persempre907 [ Sat Apr 12, 2014 8:26 am ] |
Last 907s (like mine black one) don't have the big plugs on the rear fairings and the gum on the tank. They only have some little cylindrical plugs and no gum. She came so by factory. I bought mine stock and with very little mileage. Don't worry. Ciao |
| Author: | Uwe [ Sun Apr 13, 2014 8:54 am ] |
Hello Thanks for the reply Without fixing the side cover scrubs the tank The variant where the two plugs sit in rubber would be useful So I thought Have glued hard rubber provisionally small spacer. Yesterday was the first test drive with Bridgestone S20 120/170 Runs very well Unfortunately, caused by the previous owner opened the air filter box when accelerating very strong noise. The little things are no problem. Regards Uwe |
| Author: | Bock900r [ Tue Apr 15, 2014 6:49 pm ] |
He may removed the short, round Air Intakes. Get Noisy but mine runs better without. |
