| Radiator Coolant Flush http://ducatipaso.org/forum/viewtopic.php?f=3&t=6681 |
| Author: | caryboat1 [ Sun Apr 27, 2014 10:44 pm ] |
| Post subject: | Radiator Coolant Flush |
Could someone give me the procedures to change out the coolant I opened the lower left hose from the radiator and the coolant was like black water and I want to change as it is is running hot. I just can t figure out how to refill? the forum says u can not refill through expansion tank? Then How? thx Kevin |
| Author: | Mc tool [ Mon Apr 28, 2014 1:08 am ] |
| Post subject: | Re: Radiator Coolant Flush |
There is a drain screw under the front cyl ( looks like a 6mm cap screw ... with a copper washer ) , and one on the waterpump cover . I usually just fill mine thru the tank ..... long as your not in a hurry. If I had black water in my cooling system I want to at least put a flush thru it , makes me think there has been some sort of electrollisis going on in there , or maybe the hoses are rotting from the inside out , but either way id look into that. Hamish |
| Author: | caryboat1 [ Mon Apr 28, 2014 2:36 am ] |
Thanks |
