| Melted fuel pipes! http://ducatipaso.org/forum/viewtopic.php?f=3&t=6765 |
| Author: | Projectman [ Sun Jun 15, 2014 8:48 am ] |
| Post subject: | Melted fuel pipes! |
My 907 has been sat all winter (and Spring) with 2 gallons of fuel in the tank, and some of that 'stuff' added that stops water build up due to condensation. I recharged the battery last week, but it wouldn't start; It always starts! Investigation revealed that the fuel pipes inside the tank, either side of the filter, had turned to mush. When I first replaced the fuel pump (three years ago) I also replaced those bits of hose. Is there some special type of hose that I should have used? (I used reinforced petrol pipe) Or, has the anti-water 'stuff' caused the problem or, maybe, ethanol (5% I believe) in the fuel? Yours Puzzled.
| Author: | higgy [ Sun Jun 15, 2014 9:47 am ] |
| Post subject: | Re: Melted fuel pipes! |
Ordinary fuel line is meant to have fuel on the inside only you need submersible fuel line for inside the tank with a rating of SAE 30R10 capable of handling gasoline, alcohol-extended gasoline or diesel fuel in fully immersed, mobile, stationary and marine applications Most places that handle fuel pumps will also have the required line |
| Author: | paso750 [ Sun Jun 15, 2014 9:49 am ] |
viewtopic.php?f=3&t=6277 |
| Author: | Projectman [ Sun Jun 15, 2014 10:18 am ] |
Thanks a lot chaps .I will obtain the necessary and do the job properly this time .I think I must have just shoved anything I could lay my hands on in there three years ago, just to see if it would run, and then forgotten all about it. Regards P Man |
| Author: | hazynut [ Sun Jun 15, 2014 12:52 pm ] |
Just done the same to mine I sourced the pipe from a local diesel specialist who charged me £1 for a foot its fully submersible fuel hose and looks identical to the original, so you don't have to pay a fortune provided where you buy it from there's someone there who knows there stuff. I hope this helps |
| Author: | Projectman [ Mon Jun 16, 2014 11:01 am ] |
Thanks hazynut. I've already ordered this - http://www.advancedfluidsolutions.co.uk ... 2165-p.asp as I want to get it sorted asap. |
