| Swingarm http://ducatipaso.org/forum/viewtopic.php?f=3&t=6892 |
| Author: | Uwe [ Fri Oct 24, 2014 11:32 am ] |
| Post subject: | Swingarm |
Hello Has anyone tried if the swing arm 906 fits in the 907ie. ?? The problem could be the 17-inch tires. regards Uwe |
| Author: | paso750 [ Fri Oct 24, 2014 12:22 pm ] |
| Post subject: | Re: Swingarm |
the front part of the swingarm is identical so it will fit engine and frame but it`s a little shorter, it has a different width, a different axle diameter, the pin that holds the rear caliper bracket is in a different position so the bracket of the 907ie won`t fit etc. G. |
