| 907i.e. tach problems http://ducatipaso.org/forum/viewtopic.php?f=3&t=6903 |
| Author: | docbob [ Sun Nov 02, 2014 3:53 pm ] |
| Post subject: | 907i.e. tach problems |
My tach suddenly stopped working. Occasionally dribbles up to 1000 rpm at best. Does anyone know any simple diagnostics for one of these? if it's kaput, I'm looking for one--will an earlier 906 or 750 Paso tach work? Thanks, Bob |
| Author: | ducinthebay [ Sun Nov 02, 2014 5:06 pm ] |
| Post subject: | Re: 907i.e. tach problems |
Start with the cable. Like the speedo, its a spinning cable inside housing. If they get a bit dry, they will seize up and twist off. There is a ferrel on the top side to help support the inner cable and be a bearing. Like the speedo cable and speedo drive, they are often neglected an need some lube from time to time. I just put one on my bike and the inner cable was really dry. I used some motor oil on it. Cheers, Phil |
| Author: | h1a [ Sun Nov 02, 2014 10:16 pm ] |
Hi, had similar symptoms on mine, turned out the gears in the head was worn out, parts 13 in this pic: |
