| Stebel Air Horn mounted http://ducatipaso.org/forum/viewtopic.php?f=3&t=6919 |
| Author: | ducinthebay [ Tue Nov 11, 2014 9:21 pm ] |
| Post subject: | Stebel Air Horn mounted |
found a place to put the Stebel compact air horn on the 907. Right behind the headlight, using the stock mounting tab. I used a long 6mm bolt, and used a piece of clear vinyl tubing around it for a spacer, and put a locknut underneath the existing nut welded to the frame. I bent back the mounting tab a bit so that the horn clears the headlight shell. Fits tight, but fits. Still has 6" to the fender, so it shouldn't hit the fender under full travel. Of course, the sound is just lovely. Glad I could find a place to put it on this bike. Cheers, Phil |
| Author: | higgy [ Tue Nov 11, 2014 10:23 pm ] |
| Post subject: | Re: Stebel Air Horn mounted |
I actually fit my pump above the headlight and the horns in the original place, But I am thinking of moving the pump to the relay plate since I have moved the regulator to under the seat |
