It is currently Thu Feb 26, 2026 9:39 am
 Post subject: Switch Nut?
PostPosted: Sun Apr 23, 2017 3:39 pm
This is driving me crazy. I've managed to lose the thumb nut that retains the trip meter reset cable to the dash panel. Does anyone have a spare they could sell me or tell me where on the earth I can find one? I believe it is a 14mm x 1mm. It is the switch nut that is low profile and generally tightened by fingers only so it is knurled not hex shaped.
Help!
RMR
1992 907ie
2001 900SS
2017 Supersport S
2014 BMW Sertao 650
2017 Cadillac ATS-V
 Post subject: Re: Switch Nut?
PostPosted: Sun Apr 23, 2017 9:28 pm
Go to an auto electric shop and check out the switches , probly have to buy the whole thing but more than likely there will be something to fit. ..... Boat shop , car / bike wreaker ?? :)
PostPosted: Mon Apr 24, 2017 1:35 am
Thanks Mctool. I have tried looking into auto switches but so far nothing. A bike breaker is my next stop. Funny how these $.50 pieces can cause such frustration. I figured if it is just unobtainable, I'd have my machine shop make me one, for about $75!
RMR
1992 907ie
2001 900SS
2017 Supersport S
2014 BMW Sertao 650
2017 Cadillac ATS-V
PostPosted: Mon Apr 24, 2017 8:28 am
I measure 13mm inner diameter on mine (18,3mm od, 3,65mm thickness). So M14x1 as you said. I`ll have to pick up some parts for my car today or tomorrow. If I have a chance I`ll drop by the hardware store and see what they have.
For the forum search engine: trip resetter, trip counter, trip meter, lock ring, knurled ring nut
PostPosted: Mon Apr 24, 2017 3:41 pm
The hardware store doesn`t have anything like that.
If found them on the internet tho https://www.cncwarrior.com/product-p/22905.htm
In case you order one would you order one for me as well?
May be a good idea to ask how thick it is first. Imo up to 5mm would be ok.
Or http://www.ebay.com/itm/Select-M10-M27- ... XEGLwkSsKQ
PostPosted: Tue Apr 25, 2017 4:25 am
Okay cool. This is hugely helpful, thanks! BTW what's your tag? I have ordered a total of 4, I'm happy to send you 2 once they show up here and you let me know where to send them.
RMR
1992 907ie
2001 900SS
2017 Supersport S
2014 BMW Sertao 650
2017 Cadillac ATS-V
PostPosted: Tue Apr 25, 2017 3:29 pm
sent you a pm, thx!
PostPosted: Tue Apr 25, 2017 4:16 pm
That looks like the sort of thing found on a bicycle inner tube.
2004 ST4S
2001 ST4
1987 Paso 750
PostPosted: Wed Apr 26, 2017 2:13 am
Same idea but different size. Meant to be tightened by fingers only just like on a presta valve inner tube stem.
RMR
1992 907ie
2001 900SS
2017 Supersport S
2014 BMW Sertao 650
2017 Cadillac ATS-V
PostPosted: Sat Apr 29, 2017 6:15 pm
Hi RMR,
problem solved meanwhile?
machining one of would cost less than $ 75. I can make you one for way less.
if you're interested, please PM me.
regards, Bertus
