| Removing airbox http://ducatipaso.org/forum/viewtopic.php?f=3&t=7089 |
| Author: | hazynut [ Sat Apr 04, 2015 9:17 am ] |
| Post subject: | Removing airbox |
Just removing my injectors from my bike its a bit dark in the shed and cant seem to see away of getting the rubber fittings on the air box (that connect to the throttle bodies) past the injector rail, do you have to remove the rail first before getting the airbox past or is there an easier way that I have missed cheers all Re Alistair |
| Author: | Derek [ Sat Apr 04, 2015 10:24 am ] |
| Post subject: | Re: Removing airbox |
Getting the airbox off is awkward, getting it on again is worse but I've had mine off 3 or 4 times and never had to undo the fuel rail. |
| Author: | englishstiv [ Sat Apr 04, 2015 8:33 pm ] |
If you have not put it back yet it is simple enough if you use the old fashioned method of a little bit of neat washing up liquid or silicon grease - don't go mad though just a surface wipe. Fit all the carb' unit together with just the plastic box left to fit. Obviously remove the lid and filter. Make sure you put the rubbers on the carb' bodies first aligned using the proud notch markings on them if you look at the plastic filter body you will see what I mean. Ease the box into the aperture and gently tease the outer lip of the rubber into the the box and then gently persuade the rest of the lip to follow. Start on which ever one seems easiest to work with you may have to alternate between the two. It really helps if you have a Car Trim Upholstery Prying tool to use in teasing the rubber lip into the box or even a strong but large Crochet needle Example = http://www.amazon.co.uk/Door-car-trim-u ... B001J52274 Example = https://www.etsy.com/uk/listing/1123873 ... mm-crochet Another alternative is to wrap a strong twin around the inner rim and then tease it through and over this way but you may find the rubber is a bit hard for this after twenty years. This is an old trick used with old window frame rubbers. |
| Author: | Derek [ Sun Apr 05, 2015 8:58 am ] |
| Author: | englishstiv [ Sun Apr 05, 2015 11:33 pm ] |
