| blue wire out of left side handle bar switch http://ducatipaso.org/forum/viewtopic.php?f=3&t=7102 |
| Author: | katescottageiom [ Thu Apr 09, 2015 9:51 pm ] |
| Post subject: | blue wire out of left side handle bar switch |
I can not identify this wire, was connected to frame tube just down from the re/rectifier mount. Is this a ground wire? It is blue not black, and connects into the left side handle bar switch. Diagram does not show it or I just can not see well enough at 68! |
| Author: | Derek [ Fri Apr 10, 2015 8:20 am ] |
| Post subject: | Re: blue wire out of left side handle bar switch |
It's the ground wire for the horn button. |
| Author: | paso750 [ Fri Apr 10, 2015 8:44 am ] |
Derek, that would be the grey wire. The diagram shows: https://app.box.com/shared/3elasen7q7 There`s a blue/black going to the flasher relay and a blue which seems to be low beam. |
| Author: | Mc tool [ Fri Apr 10, 2015 9:55 am ] |
And if someone has fitted a two pole relay to the headlight that blue wire might be redundant
| Author: | Derek [ Fri Apr 10, 2015 1:14 pm ] |
| Author: | katescottageiom [ Fri Apr 10, 2015 5:06 pm ] |
Thank you all, now I can push forward with confidence to the next issue, locating the correct 7mm in tank injection line. |
| Author: | nickta [ Fri Apr 10, 2015 11:57 pm ] |
Have a read of the topic viewtopic.php?t=6277 All you never needed to know about fuel line! Cheers. Nick. |
