Clutch - Looking to replace - Advice please. http://ducatipaso.org/forum/viewtopic.php?f=3&t=7146 |
Page 2 of 2 |
Author: | higgy [ Fri Jun 05, 2015 8:53 pm ] |
Post subject: | Re: Clutch - Looking to replace - Advice please. |
the " premise" behind spaying a coating of white lithium grease onto you fiction disc is to "cure" the dryed material I suppose if you wipe the disc clean afterwards not much harm would be done key on "not much" sounds like a crackpot idea to me but many claim success maybe someone should try soaking them in water and then let them air dry or just buy the suzie discs and ride on into the sunset |
Author: | MarkST [ Sat Jun 06, 2015 7:26 pm ] |
Author: | paso750 [ Mon Jun 08, 2015 10:20 am ] |
Author: | MarkST [ Mon Jun 08, 2015 12:43 pm ] |
Author: | paso750 [ Mon Jun 08, 2015 1:11 pm ] |
I've never said anything like that. A dry clutch and a wet clutch are two completely different things. Spilling a quart of oil over a dry clutch also doesn`t make it a wet clutch. If you`re not sure do try. The cars I know have a dry clutch btw. (except some with DCT) |
Author: | MarkST [ Mon Jun 08, 2015 1:21 pm ] |
Author: | englishstiv [ Sat Jun 27, 2015 10:29 pm ] |
Okay finally got to strip the clutch out today lots of rusty residue found and generally scruffy and mucky looking so after an hour or so tinkering and cleaning everything is back in place. Will see how things perform next week on my 2nd test ride after i have finished fitting the new belts. So no new clutch yet and thank you all for your suggestions. |
Page 2 of 2 | All times are UTC |
