EFI rubber dampers http://ducatipaso.org/forum/viewtopic.php?f=3&t=7164 |
Author: | persempre907 [ Wed Jun 03, 2015 6:36 pm ] |
Post subject: | EFI rubber dampers |
Any alternative source for the EFI rubber dampers? Ciao |
Author: | nickta [ Wed Jun 03, 2015 9:57 pm ] |
Post subject: | Re: EFI rubber dampers |
Hi Francesco. Which one's? The airbox end or the inlet manifold? Or something else? Cheers. Nick. |
Author: | persempre907 [ Sun Jun 07, 2015 12:28 pm ] |
The ones down to the ECU. The same are on the plate that supports the relays etc. on the left of the front fairing. Mine are broken. Ciao |
Author: | higgy [ Sun Jun 07, 2015 2:50 pm ] |
I got some from McMaster Carr. They are called Neoprene Vibration Damping Sandwich Mount, Male/Male, M6 Thread, 1/2" High, 1" Wide I think in your area or should be able to supply what you need |
Author: | englishstiv [ Sun Jun 07, 2015 10:57 pm ] |
As temporary fix cut a piece of fuel pipe to size and pass a nut and bolt through it, simple but it works and costs pennies. |
Author: | paso750 [ Mon Jun 08, 2015 10:58 am ] |
the silent blocks for the ECU are rather soft compared to standard ones |
Author: | persempre907 [ Fri Jun 12, 2015 5:06 am ] |
Many thanks everybody ![]() ![]() ![]() Ciao |
