ducatipaso.org • View topic - Rear turn signal source - stock or euro lens
It is currently Fri Nov 14, 2025 8:29 am
 Post subject: Rear turn signal source - stock or euro lens
PostPosted: Sat Jun 06, 2015 10:50 pm
I decided today was the day. Time to pull my 907 out of it's slumber. I looked and it hasn't been registered since 2008, so its been sitting for at least that long...
Long story short, when I was moving it I must have caught the right side rear turn signal on something and broke it off of it's stalk. Oops.
So now I have to either find a new stalk for it, or finally track down a Euro lens for it. I already have a Euro tail light for it but like every other one the lens is messed up.
I know, Euro lenses are impossible to find. So I'm back to looking for a US spec stalk.
Anyone out there have a spare they'd let go of? Or know where to look for one?
-Craig
 Post subject: Re: Rear turn signal source - stock or euro lens
PostPosted: Fri Jun 26, 2015 3:29 am
Sweet!
I stumbled onto a link for ECS regarding some other parts and figured I'd check for turn signals while I was there. BINGO! They have some rear turn signals in stock (according to their website). I placed the order tonight, hopefully all is well and I'll end up with a new set. I ordered two in case they are different than what I have. Strangely, Ducati has a part number for a left and a right side. I've looked and can not see a difference? Of course I broke the right side and they only have left side part numbers. Maybe it's the lens, I don't know. Whatever, if something close shows up I'll make it work. I really just need he stalk after all.
That's the good news. The bad news is, after getting frustrated with my 996 last weekend (It won't start, electrical issues…) I decided to try to fire up the 907 instead. After at least seven years of sitting, it fired up and ran. That's good, but the bad news is when I got it up to my garage door and shut it off, I heard a hissing sound… turns out it was leaking gas onto the exhaust system! :shock: Fire extinguisher in hand, it cooled off with no drama.
Yikes.
So apparently I also have a fuel leak to deal with when I'm changing the belts…
But I got a lead on a turn signal! :P
-Craig
PostPosted: Fri Jun 26, 2015 6:11 pm
fuel leak is probably a rusty tank leak, after sitting up that long, that is why my tank is black!
PostPosted: Fri Jul 03, 2015 12:35 pm
-Craig
PostPosted: Sun Jul 05, 2015 2:19 am
Hi DD.
No luck with the turn signals?
Below is a pic of a Triumph Sprint RS Indicator. It mounts the the guard like the US version of the 907. They use bullet connectors to plug into the main loom of the bike. They are pretty robust and would get you going again.
Cheers.
Nick.
PostPosted: Mon Jul 06, 2015 1:31 pm
Thanks for the lead! I'll check into those.
-Craig
