ducatipaso.org :: View topic - LED headlight bulbs - H4
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=3&t=7350
Page 1 of 2
Author:  ducinthebay [ Mon Dec 28, 2015 11:29 pm ]
Post subject:  LED headlight bulbs - H4
I just bought a Yamaha dual beam headlamp unit to put into the 907, and of course, I need to put some bulbs in it. I see that there are some really nice LED headlight bulb options out there, but the options, and i'm sure the quality, are wildly variable. There are all kind of crazy heatsinks and even ones with fans in them.
Anyone have a recommendation of which set up finds the happy medium between reasonable cost, and good performance?
Some of the first LED tailights I bought were miserably dim. My riding buddies told me my tailight was out, but it was just plain dim. Don't want to spend $100 on wimpy replacement bulbs. On the other hand, the power draw of LED bulbs and being able to run both low beams all the time would be pretty nice. I know its not the cheap option, but good lighting and less watts is attractive if I'm going to take the time change out my old headlamp.
Author:  higgy [ Tue Dec 29, 2015 1:03 am ]
Post subject:  Re: LED headlight bulbs - H4
cree lights are fine but not cheap
Author:  Sheff928 [ Tue Dec 29, 2015 8:13 am ]
The Cyclops LED bulbs have a great review on the Yahoo ST Owners Group.
I would buy them myself if they were available in the UK.
http://www.cyclopsadventuresports.com/3 ... _p_83.html
Which Yamaha headlamp did you use?
Author:  Derek [ Tue Dec 29, 2015 10:20 am ]
I tried an H4 version of one of these off eBay
The light output was great but the dip beam pattern was crap. It would have failed a UK MOT test.
Author:  ducinthebay [ Tue Dec 29, 2015 8:10 pm ]
[quote="
Which Yamaha headlamp did you use?[/quote]
I got a used Yamaha one off of Ebay for $35. I referenced this thread.
viewtopic.php?f=3&t=3256&hilit=dual+headlight
Haven't gotten any further than getting the part in the mail right now.
Author:  Sheff928 [ Tue Dec 29, 2015 8:56 pm ]
Thanks Phil,
I have been looking for ages for the type of light in the thread you refer to, but they seem to be non-existent here in the UK.
I have improved my lighting by using this type of bulb;
http://www.philips.co.uk/c-p/22109428/x ... light-bulb
in the standard headlamp, but still feel that I would like to fit a twin beam unit. I need a left-hand dip for the UK, does anyone know if the following type will fit with a little modification?
http://www.ebay.co.uk/itm/YAMAHA-FZ-600 ... xyp-BSIK37
Author:  Bluey [ Wed Dec 30, 2015 4:18 am ]
I've done this conversion a while ago and I decided to run dual 35w HID's. The HID's are wired for power through an accessory relay to the battery (less voltage loss that way) and use the factory headlight plug as the control circuit (the set up was originally meant for a car using one of the original headlight sockets as controller). So all the dashlights (lights on / high beam) work just like normal.
Looking at the current draw i couldn't run any more than 2 x 35w HIDs (mine are relatively new style low current / fast start up models). But you should keep in mind that 1 x 35W HID produces about double the light of 1 x 35W halogen (let's not argue the specifics) so by running 2 x 35W HIDs i've ended up with about 2 and a half times more light than the factory 55W halogen on high beam for only marginally more current draw.
The difference night time riding is amazing... it's like driving a modern car in terms of the light produced. With highway speeds on country roads now being fun rather than taxing.
You could run a single 55W HID for a significant improvement over factory...
I'd tried out some LED driving lights on cars and found that they never seem to have as much "throw" into the distance as HID's or even better halogens although they are fantastic at lighting up the near ground (so great work lights or "low" speed 4WDing for example).
and in terms of the current draw my battery still charges at idle with the headlights on, and can even turn my heated handgrips on low too and still be okay (but after that it's a bit close)... at actual riding rpm's everything is fine.
Author:  katescottageiom [ Wed Dec 30, 2015 9:25 pm ]
You might want to go to:
accessnorton.com page two "permanent solution for dim commando headlight
Author:  ducinthebay [ Thu Dec 31, 2015 2:11 am ]
Thanks for all the input, and especially the Norton link. (needless to say, I did not read all of the pages of the post)
I think that LED headlights have just recently turned the corner of reliability and usability from all that I have read so far. The one I am leaning towards so far is the Cyclops one. Oddly, someone else sells the Cyclops bulb for a bit cheaper.
https://www.rockymountainatvmc.com/p/38 ... AgkL8P8HAQ
20 Watts on low should be good to go.
Until I hear of a better lamp from a more reputable company, this seems to be my choice. Certainly lots of tall claims out there.
One side note, retrofitting LED bulbs into your housing is not approved by the DOT or MOT. So if you have vehicle inspections, you may not pass with an LED bulb.
Author:  higgy [ Thu Dec 31, 2015 3:28 am ]
https://www.lifetimeledlights.com/
Author:  paso750 [ Thu Dec 31, 2015 10:39 am ]
I don`t see the sense in spending so much money for a questionalble result. I`d rather go for some good H4 bulbs and update the wiring/electrics. jm2c
Author:  higgy [ Thu Dec 31, 2015 3:03 pm ]
Can't say I disagree G. I am happy with my current setup. I have a friend who put them on his Harley and swears they are by far the best lights he has ever used. Harley is a bit of a different ride. My concern is the complaints I hear with these lights while pitched over in a tight corner. What I hear is LED lighting tend to light the sky and the ground immediately in front of you leaving the exit of the corner suddenly dark. The only solution currently is adding cornering lights. Not a viable option for our taxed electrical system. I currently have silverstars on the 907 and am very happy with them now the charging system is up to the task. I can always flash all 4 elements if I find I need( deer on the side of the road) some extra beam. I do have an HID system I could install but don't much see the point at the moment
Author:  ducinthebay [ Thu Dec 31, 2015 5:08 pm ]
You raise a good point of whether this is folly or not. And I question it myself. But that's kinda why I delved into this this week.
Basically, the technology is advancing at a rapid rate, and LED lights have just now become bright enough for use in headlamps. Anything a year old is probably half the output of what you can buy now, and the price continues to drop. The landscape is changing very fast. In another 10 years, I predict LED lighting will be the norm, and a filament bulb will need to be explained to children, like an LP, 8 track or a carburetor.
My basic reason for looking into this, is twice the light output at half the power input.
Oddly, none of the major bulb makers are selling LED headlamps. (except OEM) This certainly is the frontier of the technology, and indeed does have a boatload of risk involved. And yes, its technically illegal for a road bike just about everywhere. Buyer beware. If you are risk adverse, I can not recommend it.
Author:  higgy [ Thu Dec 31, 2015 5:46 pm ]
Totally agree that the best it yet to come as the technology advances
Author:  higgy [ Fri Jan 01, 2016 8:18 pm ]
Page 1 of 2 All times are UTC
http://www.phpbb.com/
