| Ohlins rear shock absorber http://ducatipaso.org/forum/viewtopic.php?f=3&t=7383 |
Page 1 of 2 |
| Author: | Thebenelliman [ Fri Feb 12, 2016 4:57 pm ] |
| Post subject: | Ohlins rear shock absorber |
Does the Ohlins shock absorber fitted to early Paso's fit a 907 ie ? And does it improve the handling?. Mine has a new ish Hagon unit currently fitted! Not sure if they are good or not? |
| Author: | oceanhunter [ Fri Feb 12, 2016 9:55 pm ] |
| Post subject: | Re: Ohlins rear shock absorber |
I had a ohlins shock made by our local agent cost $1500 NZ, worth every penny !Now I am contemplating finding an ohlins front fork set or having the m1r customized with ohlins internals for around $700 NZ by the same people here in NZ . The rear also has remote spring preload adjustment (well worth it)makes preload changes quick and easy. |
| Author: | MarkST [ Sun Feb 14, 2016 1:25 pm ] |
| Author: | paso750 [ Sun Feb 14, 2016 2:16 pm ] |
while Thebenelliman is talking about the Öhlins shock mounted on the very early P750 models oceanhunter has installed an aftermarket Öhlins. All P750 shocks had the spring adjuster. Aftermarket Öhlins do also exist w/o. |
| Author: | Tamburinifan [ Sun Feb 14, 2016 2:19 pm ] |
It fits 907. Improves handling, do get a proper spring. I got a 52 Nm, + 90 kg driver. |
| Author: | MarkST [ Sun Feb 14, 2016 3:24 pm ] |
| Author: | paso750 [ Sun Feb 14, 2016 3:36 pm ] |
| Author: | MarkST [ Sun Feb 14, 2016 3:47 pm ] |
| Author: | Thebenelliman [ Sun Feb 14, 2016 7:14 pm ] |
So in conclusion the shock will fit and improve handling? |
| Author: | paso750 [ Sun Feb 14, 2016 7:34 pm ] |
it will fit but the question might be if the length and spring rate are identical |
| Author: | Sergio Desmo [ Sun Feb 14, 2016 9:13 pm ] |
Hello, as per Ohlins France, dims are not the same. 906 are a bit shorter if I recall correctly. for the 907ie : S46HR1C1LS (réf. DU907PFP) 1470 euros VAT incl. cheers, Sergio |
| Author: | MarkST [ Sun Feb 14, 2016 9:39 pm ] |
| Author: | 900streetfighter [ Mon Feb 15, 2016 9:40 am ] |
I put a Paso750 ohlins on my 907 10 years and had contact with tyre on mudguard under ecu with passenger. I had shock rebuilt by Harris ohlins specialist with heavier spring and still had problems. |
| Author: | Derek [ Mon Feb 15, 2016 2:23 pm ] |
| Author: | Tamburinifan [ Mon Feb 15, 2016 4:00 pm ] |
Penske & Öhlins made for 750 same length c/c as original 907 Marzocchi, FHE. Original spring 750 Öhlins according to Öhlins Sweden 42 NM, way too soft f most. W stiffer spring, ride vastly improved, it just works. No problems hitting anything, haven`t ridden much 2 up though. I assume adjusting preload & setting sag with passenger would take care of that. |
