| Ducati Diagnostic Instrument http://ducatipaso.org/forum/viewtopic.php?f=3&t=7442 |
| Author: | icekube1 [ Thu May 26, 2016 10:31 am ] |
| Post subject: | Ducati Diagnostic Instrument |
Hi everyone My back cylinder has gone quiet. There's plenty of compression and spark, so am thinking there may be some kind of timing (crank angle sensor) or fuel issue. My workshop manual talks about a diagnostic tool; blinking light variety, plugs in at the engine management unit, to check the condition of sensors. Does anyone know where I can source one, or how to make one up? Goofgling hasn't helped so far. I'm guessing the plug/cable is an industry standard type. Any advice would be much appreciated. Thanks Mike |
| Author: | Derek [ Thu May 26, 2016 3:12 pm ] |
| Post subject: | Re: Ducati Diagnostic Instrument |
Can't help you with the diagnostic but I think if the crank or timing sensor has failed it will affect the spark and injection to both cylinders. |
| Author: | icekube1 [ Thu May 26, 2016 9:28 pm ] |
| Author: | higgy [ Thu May 26, 2016 11:29 pm ] |
| Author: | nickta [ Thu May 26, 2016 11:55 pm ] |
There is a schematic on how to build one on here too. It works too! Takes about $10 of parts and about 20 minutes to solder up. Cheers. Nick. |
| Author: | nickta [ Thu May 26, 2016 11:59 pm ] |
Try this post: viewtopic.php?f=3&t=2558&hilit=flashing+light Cheers. Nick. |
| Author: | higgy [ Fri May 27, 2016 8:27 am ] |
chances are this tool is not going to help much, time to start check those connectors and grounds concentrate on the ignition circuits and key switch
| Author: | higgy [ Fri May 27, 2016 8:34 am ] |
| Author: | icekube1 [ Sat Jun 04, 2016 11:48 pm ] |
Thanks for the responses guys. Haven't looked at the bike for a week or two now, although I did quickly run a compression test on the rear cylinder; 125psi. So that's doesn't seem likely to be the problem. As I mentioned in my op, there is a big fat spark at the rear cylinder, so I'm discounting CDI/ignition circuit issues at the moment and am starting think about fuel. Bike is just sittng in the corner of the garage atm, with a sheet over it. |
