| Switch Nut? http://ducatipaso.org/forum/viewtopic.php?f=3&t=7701 |
| Author: | rmr [ Sun Apr 23, 2017 3:39 pm ] |
| Post subject: | Switch Nut? |
This is driving me crazy. I've managed to lose the thumb nut that retains the trip meter reset cable to the dash panel. Does anyone have a spare they could sell me or tell me where on the earth I can find one? I believe it is a 14mm x 1mm. It is the switch nut that is low profile and generally tightened by fingers only so it is knurled not hex shaped. Help! Thanks |
| Author: | Mc tool [ Sun Apr 23, 2017 9:28 pm ] |
| Post subject: | Re: Switch Nut? |
Go to an auto electric shop and check out the switches , probly have to buy the whole thing but more than likely there will be something to fit. ..... Boat shop , car / bike wreaker ??
| Author: | rmr [ Mon Apr 24, 2017 1:35 am ] |
Thanks Mctool. I have tried looking into auto switches but so far nothing. A bike breaker is my next stop. Funny how these $.50 pieces can cause such frustration. I figured if it is just unobtainable, I'd have my machine shop make me one, for about $75! |
| Author: | paso750 [ Mon Apr 24, 2017 8:28 am ] |
I measure 13mm inner diameter on mine (18,3mm od, 3,65mm thickness). So M14x1 as you said. I`ll have to pick up some parts for my car today or tomorrow. If I have a chance I`ll drop by the hardware store and see what they have. For the forum search engine: trip resetter, trip counter, trip meter, lock ring, knurled ring nut |
| Author: | paso750 [ Mon Apr 24, 2017 3:41 pm ] |
The hardware store doesn`t have anything like that. If found them on the internet tho https://www.cncwarrior.com/product-p/22905.htm In case you order one would you order one for me as well? May be a good idea to ask how thick it is first. Imo up to 5mm would be ok. Or http://www.ebay.com/itm/Select-M10-M27- ... XEGLwkSsKQ |
| Author: | rmr [ Tue Apr 25, 2017 4:25 am ] |
Okay cool. This is hugely helpful, thanks! BTW what's your tag? I have ordered a total of 4, I'm happy to send you 2 once they show up here and you let me know where to send them. Cheers |
| Author: | paso750 [ Tue Apr 25, 2017 3:29 pm ] |
sent you a pm, thx! |
| Author: | MarkST [ Tue Apr 25, 2017 4:16 pm ] |
That looks like the sort of thing found on a bicycle inner tube. |
| Author: | rmr [ Wed Apr 26, 2017 2:13 am ] |
Same idea but different size. Meant to be tightened by fingers only just like on a presta valve inner tube stem. |
| Author: | ducbertus [ Sat Apr 29, 2017 6:15 pm ] |
Hi RMR, problem solved meanwhile? machining one of would cost less than $ 75. I can make you one for way less. if you're interested, please PM me. regards, Bertus |
