ducatipaso.org • View topic - Syncing TBs...
It is currently Mon Mar 02, 2026 2:21 pm
 Post subject: Syncing TBs...
PostPosted: Sun Apr 30, 2017 2:22 am
Rode about a hundred miles today..new gas.....most enjoyable......runs good although there is an occasional pop...lean miss or ?.....mostly no load, mid revs.....so I'm going to ck the tps and sync.......any advise before I dive in?..I mean other than the usual procedure.....I did a search here and only got one hit..no real info....had a similar issue on my Guzzi..setting the TBs cured it...
Every place I stopped..someone had a comment...one guy saw me in Walmart, I was carrying my helmet....he asked "is that your Ducati out there?"...I say Yes..he says "man that's a sweet ride.."
I love this motorcycle...
92 907 i.e.
2016 F6B
2001 MG Jackal
1980 XS Eleven/1960 Watsonian sidecar
1974 Norton Commando/Factory Production Race
 Post subject: Re: Syncing TBs...
PostPosted: Sun Apr 30, 2017 2:52 am
Full procedure can be found in the 907ie documents folder
PostPosted: Sun Apr 30, 2017 10:01 am
Brad Black has all the info you need here
Give the article a thorough read before you start so you fully understand the procedure.
PostPosted: Sun Apr 30, 2017 5:24 pm
Thanks..good reads....
92 907 i.e.
2016 F6B
2001 MG Jackal
PostPosted: Sun Aug 20, 2017 4:36 pm
Update....this bike has been on back burner for a while..although I've ridden a few times....
Guzzi trans seals...big job...other life events to take care of....
Anyway, had the time and quiet today to pull her apart, clean up the TBs, set the TPS (which was out of spec), balance and set the CO as per Brad Black....also repaired the infamous voltage regulator connection...
Wow...what a difference!!.....
Sweeeeet!!,
Thanks for the direction and ride happy!......
92 907 i.e.
2016 F6B
2001 MG Jackal
