It is currently Fri Feb 27, 2026 11:24 pm
 Post subject: SMOKING TAILPIPE AT STOP LIGHT
PostPosted: Mon Sep 25, 2017 5:31 am
My 907 randomly blows large amounts of exhaust smoke at stoplights. Doesn't seam to follow any pattern. Just random blow of oil smoke. Not coolant , definitely smells and looks like oil. So what is allowing oil to enter the combustion chamber at stops after both low and high speed runs?
 Post subject: Re: SMOKING TAILPIPE AT STOP LIGHT
PostPosted: Mon Sep 25, 2017 5:51 am
worn guides,worn or missing seals,crankcase breather issues, too much oil improper valve lash
or any combination of all of the above
Could even be as simple as the wrong oil
PostPosted: Mon Sep 25, 2017 9:12 pm
Or even might be burning oil all the time and you only get to see it at a standstill. Does it use much oil , what do the plugs look like ..... both the same or is one oiled up ( don't mix them up as you remove them ..... )
PostPosted: Sat Feb 17, 2018 1:46 am
It blows tons of smoke when I come to a stop, it isn't a constant smoke thing. It reminds me of my high school car '74 camaro that smoked like a military grade smoke grenade at random moments. it turned out to be the trans breather thing. How do I check the oil breather valve?
PostPosted: Sat Feb 17, 2018 10:43 pm
Don't spose you have had the valve clearances done just before this started ?
PostPosted: Mon Apr 23, 2018 1:58 pm
No resetting of the valves recently. Had complete valve work done less than 2k miles ago. The bike doesn’t smoke at all except for a random event once every 20 minutes or so at speed and idle. No seaming reason. I’m thinking the breather.
