| Mufflers http://ducatipaso.org/forum/viewtopic.php?f=3&t=819 |
| Author: | persempre907 [ Sun Dec 18, 2005 3:45 pm ] |
| Post subject: | Mufflers |
I would want to mount the Monster mufflers on my 907. But I fear damages to the motor. Can you tell me if it's possible? Ciao. Francesco |
| Author: | DesmoDog [ Sun Dec 18, 2005 4:43 pm ] |
| Post subject: | |
Only way I can think of that it could do real damage to the engine is if it leaned it out quite a bit. I'm not familiar with the mufflers you're talking about so can't really say if that's likely. I'm not sure if there is a Power Commander or some such thing available for the 907, but that would be one soultion to any problems, assuming you can find someone to develop a fuel/ignition map for it then. If the mufflers you are refering to are a straight through, "race" can design, then you could get a stage one chip from one of the typical sources and be fine. |
| Author: | Finnpaso [ Sun Dec 18, 2005 8:52 pm ] |
| Post subject: | |
Buy FIM chip and also FIM additional memory board to save all changes to fuel/air map, then You have enough good things to put whatever pipes to Your 907IE :thumbup: P7 ECU need memory board,if You change map and WANT TO SAVE it, if ignition power is turned off from U bike. Read more from FIM sites on web. |
| Author: | persempre907 [ Sun Dec 18, 2005 10:44 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Mon Dec 19, 2005 6:11 pm ] |
| Post subject: | |
| Author: | persempre907 [ Tue Dec 20, 2005 4:04 pm ] |
| Post subject: | |
It's so! But the OEM monster mufflers would not be open. What you think about it? Hello baby..... Francesco |
| Author: | Finnpaso [ Wed Dec 21, 2005 5:21 pm ] |
| Post subject: | |
So, WHAT does it help if change another set of resistive mufflers??? I would change to open ones, open K & N with snorkels away, new FIM chip (&FIM memory board)with tuning to get more hp's from engine... |
| Author: | persempre907 [ Wed Dec 21, 2005 6:57 pm ] |
| Post subject: | |
Hi Annti, for me the 57 kw of 907 are enough! I'm very still driver after last tumbles!!! But then... I would buy a Monster S4... Maaaaahhhhhhh. Ciao. F |
| Author: | Finnpaso [ Wed Dec 21, 2005 7:40 pm ] |
| Post subject: | |
.... and i bought ST4S ! :thumbup: |
