| Starter Switch 92 907 http://ducatipaso.org/forum/viewtopic.php?f=3&t=8283 |
| Author: | gpsheehan [ Tue May 26, 2020 2:25 pm ] |
| Post subject: | Starter Switch 92 907 |
Any suggestions on how to check if the starter switch is working? Bike was running great. Stopped for 5 minutes and tried to restart. Heard a click/snap and then nothing. Batter is good. Thanks Gary |
| Author: | paso750 [ Tue May 26, 2020 3:31 pm ] |
| Post subject: | Re: Starter Switch 92 907 |
it could be the relay. But if it clicks there should be a voltage output towards the starter. Try to put the kill switch in off position. Press the starter button and then flick the switch to on position. Sometimes this works. |
| Author: | Mc tool [ Tue May 26, 2020 7:29 pm ] |
| Author: | gpsheehan [ Tue May 26, 2020 8:27 pm ] |
Thanks guys, Will let you know if it works. Also have some suggestions from Steve S. that I will try if the kill switch trick doesn't work. |
| Author: | paso750 [ Wed May 27, 2020 7:15 am ] |
I made that comment too quickly. It won't work on the 907IE as the kill switch powers one of the main relays. On the P750 it's different. There the the coils get their 12V via the kill switch. Sometimes if there's a voltage drop due to bad electrical connections flicking the kill switch while turning the engine over may overcome contact problems inside the switch at least enought to get the coils the minimal voltage they require to create a spark and fire the engine up. |
| Author: | Derek [ Wed May 27, 2020 9:50 am ] |
Assuming the plug hasn't dropped out of the solenoid the quickest check would be to connect a lamp across the 2 terminals of the solenoid connector. When the starter switch is pressed it should light up. If it doesn't either the starter switch isn't making contact or the kill switch isn't making contact. If the kill switch isn't contacting the fuel pump won't run at swich on and the charge warning light won't come on either. |
| Author: | gpsheehan [ Fri Jun 12, 2020 1:53 am ] |
Gentlemen Tried the kill switch trick and it worked! Thank you. |
