ducatipaso.org
http://ducatipaso.org/forum/
Fuse Block
http://ducatipaso.org/forum/viewtopic.php?f=3&t=8329
Author:  blakduc1 [ Mon Sep 07, 2020 1:15 pm ]
Post subject:  Fuse Block
Anyone ever replace the fuse block on a 907? Mine is falling apart. Literally crumbling. Whatever the material is, it was not made to withstand the test of time.
Does anyone have a good aftermarket replacement for that item? I did order one for marine application, but it is a little large. It may work, and is high quality, but I think I will look for one closer to the original size.
Author:  higgy [ Mon Sep 07, 2020 3:02 pm ]
Post subject:  Re: Fuse Block
Eastern beaver has some good ones
Author:  Willo [ Mon Sep 14, 2020 5:26 am ]
When mine fell apart I used a Narva 54420BL. I used insulated spade connectors and bent the terminals a bit for clearance.
Willo
Wannon Victoria Australia
Page 1 of 1 All times are UTC
http://www.phpbb.com/
