| Starting on one cylinder after a long stop http://ducatipaso.org/forum/viewtopic.php?f=3&t=8332 |
| Author: | angelix [ Mon Sep 21, 2020 8:00 pm ] |
| Post subject: | Starting on one cylinder after a long stop |
it has been a couple of years that it is happening, after leaving the bike in storage for 4-6 months , it will start on one cylinder, then after few seconds it will run properly. the first time I though an injector was sticking but I am not really sure... any similar esperiences? Thanks
| Author: | higgy [ Tue Sep 22, 2020 3:33 am ] |
| Post subject: | Re: Starting on one cylinder after a long stop |
If I had to guess I'd say after months of sitting air in the fuel line Would be the likely cause or maybe a sticky or shot Check valve in the pump Quickest way to figure out fuel issues as Im sure you know is a pressure gauge And this assumes the more mundane and common issues are not in play....clogged filter, intank fuel lines , funky spark, ground problems,ignition switch...you've been there |
| Author: | higgy [ Sat Oct 10, 2020 3:46 am ] |
Dont ya just love it when folks post question then dont follow up
| Author: | Frank.61 [ Sat Oct 10, 2020 7:52 am ] |
Hi Higgy, I understand you: i assume he's still cranking Frank (I've had similar experience once due to stale - modern s**t - fuel) |
| Author: | higgy [ Sat Oct 10, 2020 6:02 pm ] |
Anglelix has been around for for a long time,kinda surprised actually
| Author: | angelix [ Wed Oct 14, 2020 9:47 am ] |
sorry guys , I have been working hard finishing a long term project and I am revamping my lab so I lost track of the time. my 907 is in Italy, I am in the UK, so I will be in position to check it only when I am back there. when it runs , it does it flawlessly, but it has been already a couple of years that the first start after a long stop (3-5months) is proving somehow "difficult" Usually it cranks 1 turn and a half and the engine fires, but lately I had a couple of episodes when it starts after 4-5 turns and then rund on 1cylinder for few seconds. When it happended the first time I got some injector cleaner, this time I just filled the tank with fresh petrol and went for a ride (and what a ride it was 10 months I was not touching the little Elefantino) unfortunately the issue is not repeiting itself every time so cannot pin point which cylinder is not firing. I need to find sometime to do some work on it I am doing 500miles a year so there is little wear ,neverthless the years pass by and few things need addressing like the intank hoses and fuel filter, last time I did those was 15 years ago. by the way, do you know the hose diameter? 1/4" or 5/16" |
| Author: | Tamburinifan [ Sat Oct 17, 2020 2:26 pm ] |
First thing I`d try is a fresh set of plugs, KISS... |
