| Plug identification? http://ducatipaso.org/forum/viewtopic.php?f=3&t=8407 |
| Author: | Crumpati [ Fri Aug 13, 2021 11:46 pm ] |
| Post subject: | Plug identification? |
Hi there, can anyone tell me what the two plugs are that along the top frame rail on the lefthand side? Two identical with the C shaped spring clip joining them. One seems to go into the housing near the clutch slave. I think they are both labeled "Conne Commando" In the parts diagram, thanks |
| Author: | nickta [ Sat Aug 14, 2021 3:19 am ] |
| Post subject: | Re: Plug identification? |
Inductive pickups for the Ignition possibly? The wiring (2 wires in each) that goes into the loom will have an orange and grey/black wire in one and violet/black and yellow/blue in the other. Labelled 33 and 34 in the wiring diagram. Don't mix them up. Engine won't run or run really badly if it does start. There is a post on the forum about this somewhere... Cheers. Nick. |
