| Fork oil weight http://ducatipaso.org/forum/viewtopic.php?f=3&t=854 |
Page 1 of 2 |
| Author: | pencilbeam [ Tue Jan 24, 2006 12:18 am ] |
| Post subject: | Fork oil weight |
What fork oil weight should I use in normal temperatures like California? (Not Finland :laugh: ) And how to measure the correct amount in each leg? Cleaned and replaced seals and dust cover and ready to finish the job. Thanks! |
| Author: | Skins [ Tue Jan 24, 2006 5:59 am ] |
| Post subject: | |
The factory recommendation is SAE10, which should be suitable for California. |
| Author: | Finnpaso [ Tue Jan 24, 2006 8:27 am ] |
| Post subject: | |
Hey, Pencilbeam, also in Finland NORMAL temperature, what is surely liitle lower, that in land of "hope and glory :laugh: :laugh: :laugh:" , but to topic, in 750 Paso, its mentioned that 350cc in both fork, but in 907IE it was something, like 180mm from top(if i am remembering right). Those can bo found from workshop manuals. Surely U have one |
| Author: | pencilbeam [ Tue Jan 24, 2006 1:51 pm ] |
| Post subject: | |
Thanks very much! The only thing normal about California is the temp. :laugh: |
| Author: | Rogero [ Tue Jan 24, 2006 7:42 pm ] |
| Post subject: | |
You can't smoke anywhere in that state |
| Author: | Finnpaso [ Tue Jan 24, 2006 8:18 pm ] |
| Post subject: | |
..... & i have heard, that there are very tight rules about loud motorbikes, hard emission rules, etc..... :laugh: Can anyone confirm that? |
| Author: | pencilbeam [ Tue Jan 24, 2006 8:45 pm ] |
| Post subject: | |
| Author: | Marinus [ Tue Jan 24, 2006 9:19 pm ] |
| Post subject: | |
| Author: | pencilbeam [ Tue Jan 24, 2006 10:53 pm ] |
| Post subject: | |
| Author: | Marinus [ Tue Jan 24, 2006 11:23 pm ] |
| Post subject: | |
| Author: | pencilbeam [ Tue Jan 24, 2006 11:37 pm ] |
| Post subject: | |
| Author: | Finnpaso [ Wed Jan 25, 2006 6:30 pm ] |
| Post subject: | |
Marinus, i have about 10 very close Ducati friends here in this part of Finland and some have raced lot with 888 in earlier years and they have plenty of knowinig about fron forks. 90% of them drive currently with 5W oil, and temps are hear about 20...28C at summertime. Same with jap bikes also.... I dont know those farenheits at all, so sorry for that... I think they belong to U.K, or ... somewhere... :laugh: I have heard, that they drive in U.K different side of roads, than in other world... :laugh: |
| Author: | Marinus [ Wed Jan 25, 2006 8:11 pm ] |
| Post subject: | |
All I know about Fahrenheit is that when its – 40c it’s also -40f and either way its fxxxxx cold. I live in a place where it never goes under zero c. :thumbup: We’ll leave the Fahrenheit :confused: to the Americans and they drive on the same side of the road as you. A lot of the roads I ride my bike on have no lines in the middle and little other traffic so I can pick my own side Hard or soft, thick or thin it’s all personal preference. I’m sure everyone has there own idea about what feels best :laugh: . |
| Author: | jomo [ Sun Jan 29, 2006 9:51 am ] |
| Post subject: | |
| Author: | Marinus [ Sun Jan 29, 2006 10:48 am ] |
| Post subject: | |
This comes from http://www.strappe.com/suspension.html There is more info there so take a look. knowing what the reason for the air is helps. So now you know it's not about haw much oil is in each fork but how much air is each fork. Oil level: The fork oil's primary function is to be pushed through small holes to damp the rebound of the spring. In an automotive shock, this is the only function of the oil. However, in a bike fork there is the spring, the oil, and the trapped air above the oil. This air is important - air, when compressed, acts like a spring, but with a rising rate. That is, the more it's compressed the more force it takes to compress it a bit more. Most fork springs, on the other hand, are linear (straight rate). The idea is to set the oil level so that the right amount of air is trapped to keep the forks from solid metal contact at full compression. (Obviously, bottoming the fork internals leads to a harsh ride and component damage.) The right amount of oil will allow nearly all of the fork travel to be used in riding and stopping. How do you find out what's needed? First, with the cap and spring out of the fork, find out what the maximum travel is (when the fork internals bottom out) {Ihave not done this but the paso book said 140mm}. Then reassemble the forks and install the recommended amount of oil. Second, once the forks are on the bike, take a zip tie (plastic cable tie) and put it around the fork tube above the slider - make it tight enough that it'll stay where it's pushed by the slider's dust cap. Third, go for a ride. Do some hard stops with the front brake. Do stoppies if you can. Fourth, back in the shop, compare the position of the zip tie with the previously measured maximum travel. I like to get the working travel to within 1/4 inch of maximum. If the working travel is too little, remove a bit of oil. If it's near or equal to the max, add some. The best way to do this is to remove the fork springs (support the front end first) and measure the oil level in each leg with the forks totally compressed. Measure the distance from the top of the tube to the oil level. If you want to make changes, I'd suggest a level change of no more than 10mm at a time. It's hopeless to try to measure oil volume accurately once it's in the forks, that's why we measure level instead. Here's an example: Take a look at my SV650's log - you'll see in column 7 I set the oil level at 124mm, which yielded a total travel of 112mm, 10mm short of the target of 122mm. In column 8 I reduced it to 127mm, for a total travel of 115mm. In column 9, I dropped it further to 132mm, which produced travel of 122mm. Right on target. Then in column 10 I cut the springs to make them stiffer yet and started over. Oh, yeah: you should leave the zip tie on the fork leg. It will tell you if your travel changes, which will happen if you lose any fork oil... and anyway, it lets the cognoscenti know you're hip! Almost as good as tiny rubber balls on the edges of your tires. |
