| Racing chip? http://ducatipaso.org/forum/viewtopic.php?f=3&t=964 |
| Author: | persempre907 [ Mon Mar 20, 2006 2:30 pm ] |
| Post subject: | Racing chip? |
Hi everybody, I have bought on eBay from a canadian seller a couple of stock mufflers. The seller has shipped to me also a chip (n. 91270201A) that increases the performances of 907 ie USA. On the attached paper I can read that: "With these modifications you'll change the data submitted for the motorcycle type approval; therefore use the modified motorcycle only within closed tracks". On the chip it's a label: "DUCATI 907ie -023U-". Could I use it on my european 907? How does much would be the performances increase? Ciao. |
| Author: | Finnpaso [ Mon Mar 20, 2006 3:16 pm ] |
| Post subject: | |
That is NORMAL USA chip for 907IE, and that chip is designed to tune engine MORE LEAN, than normal 907 Chip, what is marked -023- That "U" means, that its USA chip. Its safe to use that with EURO bike and with normal mufflers, but it is NOT so good, as EURO chip)-023- ; what is more rich mapped. Dont use ever that USA chip with open muflers, or then You have maybe big problems with burned exhaust valves! You are warned now! :thumbup: |
| Author: | persempre907 [ Mon Mar 20, 2006 4:01 pm ] |
| Post subject: | |
Therefore, this chip wouldn't give more performances. Only more troubles :thumbdown: !! Thanks Antti |
| Author: | Finnpaso [ Mon Mar 20, 2006 8:00 pm ] |
| Post subject: | |
Yes, not anymore horsepower, cause more lean fuel ratio, than in normal EURO chip -023-. Near allways USA Ducatis have been fitted with leaner chips, cause there are tighter emission rules = leaner fuel ratio. So, NO "RACING chip", i am sorry, Francesco! |
| Author: | 1564 [ Thu Mar 23, 2006 3:31 am ] |
| Post subject: | |
when i purchased 907 the owner gave me what he said was stock u.s. chip(ducati 907ie 023u) checked chip presently in bike with k&n filter, open staintunes the chip is fim 907bp692, any one can confirm this chip 907bp692 is the right set up for mods...no other mech. mods/stock motor |
| Author: | persempre907 [ Fri Mar 24, 2006 7:36 am ] |
| Post subject: | |
The seller probably have sold her OEM parts after he tuned the bike Ciao |
