| NEED PARTS FOR MY 906 BAD!!! PLEASE HELP! http://ducatipaso.org/forum/viewtopic.php?f=4&t=1957 |
| Author: | wineliving [ Fri Aug 24, 2007 3:14 am ] |
| Post subject: | NEED PARTS FOR MY 906 BAD!!! PLEASE HELP! |
Hello to my new friends and Duc lovers. Got a great Paso with the usual details that need completing. I need some parts for my 1990 906 to make it as perfect as possible. Here is the list: 1. New taillight assembly including lens (it has built in turn signals) 2. Left/Right front turn signal lenses (I'll take the whole assembly) 3. Round mirror (if you have suggestions for replacement, rather than original, I am open. 4. Trim piece that goes under the instrument cluster 5. Front upper fairing (headlight area, aka windscreen) 6. A working clock. 7. Risers would be nice (aftermarket item) Thank you all in advance for any help and suggestions. |
| Author: | Finnpaso [ Fri Aug 24, 2007 12:26 pm ] |
| Post subject: | |
| Author: | paso750 [ Sun Aug 26, 2007 5:40 pm ] |
| Post subject: | |
| Author: | gail [ Mon Aug 27, 2007 10:53 am ] |
| Post subject: | |
| Author: | wineliving [ Tue Aug 28, 2007 5:00 am ] |
| Post subject: | |
Thanks for some of the advice. Here is an updated list: 1. New taillight assembly including lens (found and purchased-dealer) 2. Left/Right front turn signal lenses (found and purchased-Ebay) 3. Round mirror (if you have suggestions for replacement, rather than original, I am open. (Joan's Fabric .99 cents 4" perfect fit, dealer wanted $40.00 usd) 4. Trim piece that goes under the instrument cluster (may use diamond plate and fabricate piece) 5. Front upper fairing (home repaired job, looks tolerable) 6. A working clock (still hoping) 7. Risers would be nice (going to a machine shop with suggested plans, thank you kindly for that info) 8. New Item: Cooling expension/resorvois tank. Thanks guys/gals for reading my post and offering suggestions. |
