| 907 Plug & switch http://ducatipaso.org/forum/viewtopic.php?f=4&t=1963 |
| Author: | Cybermunster [ Thu Aug 30, 2007 9:19 pm ] |
| Post subject: | 907 Plug & switch |
Looking for; 1- The plastic terminal/plug that connects the sidestand warning light, fuel gauge, neutral light wires to the bottom of instrument board. I know, another probable "hopeless" search but trying anyway. 2- Rear brake switch as the current one I have to apply excesive pressure to activate. Otherwise enjoying this fine machine....Thanks!! :thumbup: |
| Author: | wineliving [ Fri Aug 31, 2007 2:28 am ] |
| Post subject: | |
One part was on Ebay but now it is gone. The rear brake switch you should be able to get from the dealer. I believe it is a Brembo part. On the rear switch make sure your brake fluid pressure/level is correct first prior to assuming it is the switch. Just some troubleshooting thoughts. I'll keep my eyes open. |
| Author: | Cybermunster [ Fri Aug 31, 2007 5:45 am ] |
| Post subject: | |
Thank Wine...that might just be it as the shop installed new braided brake lines recently, maybe it'll be a "need" for a bit of brake fluid. |
| Author: | Tamburinifan [ Fri Aug 31, 2007 1:40 pm ] |
| Post subject: | |
Got my switch from a Ducdealer. |
| Author: | Cybermunster [ Fri Aug 31, 2007 1:44 pm ] |
| Post subject: | |
Thanks for the info. |
