| WTB: Paso parts***UPDATED June 10th*** http://ducatipaso.org/forum/viewtopic.php?f=4&t=3311 |
| Author: | fredskidoo [ Mon May 11, 2009 9:14 pm ] |
| Post subject: | WTB: Paso parts***UPDATED June 10th*** |
Hello all . . . I am in need of some parts for my Paso 750: Lefthand side oil cooler cover (attaches to fairing)****ACQUIRED Rubber fittings for both oil coolers (in the fairings) **** ONLY NEED 1 SET NOW Left side oil cooler (either side will do actually)****ACQUIRED Fairing for headlamp****ACQUIRED Left and right flasher/mirror assemblies****ACQUIRED Battery strap****N/A Rear brake foot lever with rubber Front rubber gromet for gas tank to frame****ACQUIRED Rear tail peice (on top of the taillight)****ACQUIRED 130/60 ZR16 front tire Speedometer cable****ACQUIRED Tachometer cable Both oil filters Weber carburetor rebuild kit Rear fender/license plate holder I AM interested in any other compatible parts you may have for sale as well - just run it by me. Thanks! |
| Author: | paso750 [ Tue May 12, 2009 7:20 am ] |
| Post subject: | Re: WTB: Paso parts |
there is no battery strap on the Paso. You should add your location to your profile, that would be helpful if looking for parts. G. |
| Author: | Harigeharry [ Wed May 13, 2009 7:21 am ] |
I got a complete Weber carb. I might have a tail piece (have to look it up in the shed). And a set of black wheels with tyres (front so so state, rear reasonable). |
| Author: | higgy [ Wed May 13, 2009 10:38 am ] |
How much for the weber? |
| Author: | Harigeharry [ Thu May 14, 2009 6:16 pm ] |
Don't really know what's worth. When I look around on the web I see prices from around E100 (somewhere on this forum) till E300 when It's used on a Buggy or Fake American Musclecar. Say E100? |
| Author: | higgy [ Thu May 14, 2009 11:03 pm ] |
What is the serial number on the weber and do you know what jetting it has. For 100 euro it will have to have exactly what I am looking for to be worth the price In particular I need to know which emulsion tubes your weber has installed. Be nice to know which auxilliary venturi tubes you have as well for future reference. Also which main venturis. |
| Author: | Harigeharry [ Fri May 15, 2009 8:14 am ] |
I'll look it up for you and post some pics... Hope fredskidoo don't mind us doing business. fredskidoo, Weber kits are available on ebay for a few dollars. |
| Author: | higgy [ Fri May 15, 2009 9:46 am ] |
most weber parts can be had at They also are in California |
| Author: | fredskidoo [ Fri May 15, 2009 10:40 pm ] |
Update on WTB: Paso Parts. As of today it looks like I have acquired: tail piece front tire speedo cable rubber gromets to hold oil coolers Thanks to Higgy for the Weber link, Desmo_Demon for a speedo cable and Ed at guzzitech.com for the tail piece. No worries Harry and Higgy . . . easy |
| Author: | Harigeharry [ Sun May 17, 2009 5:48 pm ] |
Its a bit dirty after 20 years of Paso service. Absolutely no corrosion.. |
| Author: | higgy [ Mon May 18, 2009 10:24 pm ] |
very nice,but not what I am looking for,gonna take a pass..........sorry |
| Author: | ducapaso [ Tue May 19, 2009 5:36 am ] |
It's ok, but how it looks inside? You need to pull the cap! |
| Author: | Desmo_Demon [ Tue May 19, 2009 3:13 pm ] |
| Author: | Rodney [ Sun Jun 21, 2009 9:05 am ] |
| Post subject: | Re: WTB: Paso parts***UPDATED June 10th*** |
Hi. i have a few spares i am getting rid of, -front fairing bracket -front mudguard -rear cowling -headlight -taillight (yellow indicators) -rear footpegs -rear grabrail (needs rechroming) -repo near side mirror / blinker assembly (left hand side) -near side handle bar (left hand side) -fuel sender -new brake lever -new front sprockets x2 -new rear sprocket -rear axle -new rear disk -brake master cylinder and lever -original webers x2 -airbox -used front disks -wiring harness -ventura rack -staintune pipes if your interested in any of these let me know thanks Rodney |
