| 750 Paso Limited in Virginia http://ducatipaso.org/forum/viewtopic.php?f=4&t=3339 |
| Author: | jcslocum [ Thu May 21, 2009 1:53 am ] |
| Post subject: | 750 Paso Limited in Virginia |
From Craigslist $1800 http://roanoke.craigslist.org/mcy/1177042529.html Needs some easy engine work but appears to be all there. |
| Author: | paso750 [ Thu May 21, 2009 10:18 am ] |
| Post subject: | Re: 750 Paso Limited in Virginia |
strange side fairings. No air conveyors, no side oil coolers |
| Author: | jcslocum [ Thu May 21, 2009 3:35 pm ] |
I asked for more info |
| Author: | persempre907 [ Thu May 21, 2009 9:22 pm ] |
Very strange fairings. I wonder if she's a real "limited". Ciao |
| Author: | jcslocum [ Fri May 22, 2009 12:17 am ] |
from the current owner: it was a running driving bike when i bought it a few years ago,but it had low compression,so i took the heads off and found bad valve guides,i took heads and cylinders to a machine shop and he removed the bad guides and cleaned up cylinders and told me to put standard rings back in.i have new guides and a bunch of new o-rings and gaskets,but never got back to it.you are right about the fairing,someone filled in the air scoops on the sides,but i bought originals on e-bay that will go with bike. i will try to take more pictures if you are still interested. |
