| Left M1r fork leg needed! http://ducatipaso.org/forum/viewtopic.php?f=4&t=4746 |
| Author: | Tamburinifan [ Fri Apr 15, 2011 1:00 am ] |
| Post subject: | Left M1r fork leg needed! |
The one w no rebound fuction. My wheel axle threads are gone, need just the lower part of left M1r leg. |
| Author: | 907pasonut [ Fri Apr 15, 2011 4:44 am ] |
| Post subject: | Re: Left M1r fork leg needed! |
try iangowanloch@bigpond.com he may have one...good luck ![]() actually this one might be better gowanloch@ozemail.com.au |
| Author: | avhpaso [ Sun May 29, 2011 10:35 am ] |
did you find a leg I am looking for the RH side leg |
| Author: | Tamburinifan [ Sun May 29, 2011 3:04 pm ] |
Not found. |
| Author: | paso750 [ Sun May 29, 2011 3:19 pm ] |
if Gert finds one it won`t help you as the 907ie fork is not the same. |
| Author: | Duc750 [ Thu Jun 02, 2011 9:31 pm ] |
I thought the lower was the same but the actual tube longer, or are the threads different too? |
| Author: | paso750 [ Fri Jun 03, 2011 8:31 am ] |
the 907ie has 40mm brake caliper mounts, the P750/906 has 108mm. Gert has a 907ie, avhpaso a P750. |
| Author: | Duc750 [ Fri Jun 03, 2011 9:52 am ] |
Got you, wasn't thinking about calipers (but should have been) |
| Author: | paso750 [ Mon Jun 06, 2011 10:53 am ] |
seen this ? It doesn`t say which Paso it`s from, the price is a bit high and the position of the left dust seal looks a bit odd considering all seals were replaced http://cgi.ebay.de/Marzocchi-fork-41-7- ... 415a61a926 |
| Author: | angelix [ Tue Jun 07, 2011 9:50 pm ] |
