It is currently Thu Mar 12, 2026 12:38 pm
 Post subject: FS: Dash, Fairings, Rim, rotors, carb slides, clutch master
PostPosted: Thu May 12, 2011 12:16 am
For sale:
1988 Paso 750 Dash with attached foam and clear plastic cover. in working condition and in good shape but plastic cover is slightly cracked. odometer around 19,000. no mounting screws.
1988 750 Paso left side lower fairing original blue/black. has some light scratches and a ding thru the fiberglass in the oil cooler air scoop area
1987 750 Paso left side lower fairing has been painted "viper blue". color almost matches original but not quite. pristine condition.
1988 750 paso left side air cooler fairing original blue. heavily scrathced and cracked in the center
Ducati 16" oscam rim with Pirelli MTR01 Dragon 130/70 zr16 tire on it. tire is mostly worn but the rim is in good shape. bearings spin
2 front brake rotors. lightly used
2 sets of brake rotor bolts
left side blinker lens with 1 crack that is hardly noticable
2 dellorto carb slides. moderately used
complete clutch master cylinder with choke, blinkers, passing all intact. well used but fully functional
I have pics for all items, pm me with a price you have in mind, looking to get rid of it all, you might also see it on ebay. thanks for looking!
2001 996 SPS
1988 750 Paso
Users browsing this forum: No registered users and 86 guests
