| Exhaust pipes and clutch cover http://ducatipaso.org/forum/viewtopic.php?f=4&t=5020 |
| Author: | persempre907 [ Sun Aug 21, 2011 3:34 pm ] |
| Post subject: | Exhaust pipes and clutch cover |
http://www.ebay.com/itm/Ducati-750-Paso ... _515wt_936 http://www.ebay.com/itm/Ducati-F1-etc-3 ... _515wt_936 Ciao |
| Author: | paso750 [ Sun Aug 21, 2011 5:43 pm ] |
| Post subject: | Re: Exhaust pipes and clutch cover |
someone will buy that cover for lots of money, keep it for years and put it up on ebay again. Wanna bet ? Try to find the clutch piston for that cover. The piston is 31mm, the Paso`s is 26mm, the F1`s 28mm and aftermarket slave cylinders for newer Ducati models vary from 28-30mm. |
| Author: | Stingray230SX [ Fri Sep 16, 2011 8:04 pm ] |
i thought all the clutch covers were the same?? it just covers the dry clutch mech? my 907 has a silver aluminum cover, somewhere somehow it has an unsightly gouge in it, i would like to replace it eventually with a modern carbonfiber or open type aluminum one, and i thought most of them fit?? thanks doug hunt |
| Author: | paso750 [ Fri Sep 16, 2011 8:36 pm ] |
no. You have a 907ie with the clutch piston on the left engine side so you can use just any cover or even run it w/o one. The F1, 750S, Paso750 etc have the clutch piston in the cover. The covers from the models mentioned look the same but use different size pistons. G. |
