It is currently Tue May 05, 2026 11:00 am
[ 7 posts ] |
| Author |
adysax
Post subject: 906 engine block Posted: Wed Jun 20, 2012 12:23 pm |
Joined: Wed Jun 20, 2012 12:13 pm Posts: 10 Location: UK
anybody know where I can find a replacement drive side (left) engine block as mine has smashed after the chain snapped. see photo
| Top |
900streetfighter
Post subject: Re: 906 engine block Posted: Wed Jun 20, 2012 2:47 pm |
Joined: Wed Oct 27, 2010 5:52 pm Posts: 364 Location: Essex UK
You'll probably have to get a pair of cases or that might be repairable Where are you?
| Top |
Post subject: Re: 906 engine block Posted: Wed Jun 20, 2012 8:01 pm |
| paso grand pooh-bah |
Spotted one yesterday on us ebay, think seller was guzzitech.
_________________ Gert
907 I.E. -91 M900 -97 MTS 1100s -07
| Top |
adysax
Post subject: Re: 906 engine block Posted: Thu Jun 21, 2012 12:14 pm |
| Top |
Post subject: Re: 906 engine block Posted: Thu Jun 21, 2012 8:11 pm |
UK ? USA? AUS?
| Top |
samandkimberly
Post subject: Re: 906 engine block Posted: Thu Jun 21, 2012 8:43 pm |
Joined: Thu Apr 03, 2008 4:38 pm Posts: 149 Location: Boston, MA
is that the only problem, and is it still in the bike? If so, repair it - cut/bend a piece of AL to fit the hole as best as you can, clean everything real well with lots of solvent, then sand/file everything nearby so that there is fresh, rough metal everywhere glue might end up. Glue in place with a good 24 hr epoxy - I've used MarineTex, PC7, and JB Weld all with good luck. If needed, build up a solid layer on top of the AL you cut to fit as thick as the original casting or thicker so the cover can seat - you can do this with more regular epoxy or you can use epoxy putty. Let sit for 2-3 days, then flat file the sealing surface down to the same level as the original machine work or even a little lower - you don't want the compressive forces of the cover working to break the epoxy bond. Seal it with a little silicon when you reassemble.
I've fixed much worse, and never had a repair like this fail, as long as proper attention is paid to the prep work.
Sam
| Top |
adysax
Post subject: Re: 906 engine block Posted: Wed Jun 27, 2012 9:10 am |
| Top |
[ 7 posts ] |
Users browsing this forum: No registered users and 5 guests |
