ducatipaso.org • View topic - Need honest opinion!
It is currently Sun May 03, 2026 2:50 pm
 Post subject: Need honest opinion!
PostPosted: Wed Aug 10, 2005 2:56 pm
Am I asking to much for my Paso?
Theo :confused:
PostPosted: Sat Aug 13, 2005 8:31 pm
:cool:
I'm a beginner with computers, Theo, and a slow learner, but I figured out how to post pictures with my Windows XP Home Edition. You just bring up the list of your pictures, then over on the left click on 'Publish this picture/file to the web', then follow the wizard. You will need the pictures ID or address, which is best got by right-clicking on the picture, then left-clicking on 'Properties', then copying the ID or address by address by running the mouse over it while holding the left click down and then doing Ctrl+C. Paste what you copied into where it is required by doing Cntr+V.
When you do your posting into this site, where you want to put the picture, click on the Img* box above, then past in the picture ID or address (no space after [img]) then click on the Img* box above again (no space after the ID or address). Finish the post, click on Submit, and the post, with the picture, should come up in the Topic.
Good luck!
PostPosted: Sun Aug 14, 2005 1:32 am
Skins,
Thanks, I will give it a try
Theo
PostPosted: Sun Aug 14, 2005 2:27 am
:confused:
Er, Theo, I think in my second paragraph above, where I refer to the picture's ID or address, it will be the new ID or address for the picture (probably considerably longer than the first ID or address) which the wizard has organised for you. Anyway, if you get that far, you'll be able to figure it out, I reckon.
