| WTB Tachometer cable for 907ie. http://ducatipaso.org/forum/viewtopic.php?f=4&t=5924 |
Page 1 of 2 |
| Author: | st2sam [ Sun Mar 31, 2013 1:01 pm ] |
| Post subject: | WTB Tachometer cable for 907ie. |
Tachometer cable for 907ie needed. I found a new one for sale here but the member has not been on line for two years... Would cables for a different model fit? Any help would be appreciated, thanks... |
| Author: | Derek [ Sun Mar 31, 2013 3:39 pm ] |
| Post subject: | Re: WTB Tachometer cable for 907ie. |
I needed a replacement and found they are no longer available from Ducati so I fitted one from a 900SS. It is about 100mm longer but the excess length is lost behind the headlamp and it works just fine. They are still available from Stein Dinse; |
| Author: | persempre907 [ Sun Mar 31, 2013 4:36 pm ] |
The 750 cable is too short for the 907. If you don't manage to find a 907 one, buy a SS one. Ciao |
| Author: | st2sam [ Sun Mar 31, 2013 10:02 pm ] |
Thanks for the quick response guys. Also, thanks for the link Derek but ordering from the UK is a last resort. If anyone else has idea's, or one for sale, please chime in. I wonder if it's possible to just replace the inner piece, as the outside cover is in good shape? Has anyone tried this ? |
| Author: | Tamburinifan [ Sun Mar 31, 2013 11:42 pm ] |
Yes. Quite easy to do. |
| Author: | englishstiv [ Mon Apr 01, 2013 10:30 pm ] |
Give these guys an email http://www.carrotcycles.co.uk/custom-ma ... fo_10.html If enough people are interested we could get a batch made up I am happy to send them original pattern one to work off. You could even make your own using their supplied parts. |
| Author: | st2sam [ Tue Apr 02, 2013 2:24 am ] |
| Author: | st2sam [ Fri Apr 05, 2013 11:31 am ] |
I'm going to try and solder it this weekend, I'll post my results. If anyone has one for sale (in the States) I would much rather replace than repair. thanks, Sam... |
| Author: | Tamburinifan [ Fri Apr 05, 2013 1:39 pm ] |
Reading the 907 forum ("Breaking in UK) can be rewarding http://item.mobileweb.ebay.co.uk/viewit ... 6412447503 |
| Author: | Derek [ Fri Apr 05, 2013 2:33 pm ] |
A new 900SS tacho cable cost me £24.28 from my local dealer. |
| Author: | Duc750 [ Fri Apr 05, 2013 11:57 pm ] |
Venhill in the UK will also make them - they need a pattern though but once they have the pattern can make to order - if I can get down to Surrey before i put the engine back in mine they can use my speedo, Tacho and throttle cables as patterns. Also talking to someone about making a new coolant reservoir and chain sliders ! Coolant res I have as a spare for a pattern but I could do with a good condition or new old stock chain slider if we get to that point. |
| Author: | st2sam [ Sat Apr 06, 2013 1:45 am ] |
| Author: | st2sam [ Sun Apr 07, 2013 12:44 pm ] |
| Author: | Derek [ Mon Apr 08, 2013 8:58 am ] |
| Author: | st2sam [ Mon Apr 08, 2013 11:36 am ] |
[/quote] A cable from any carbed 750/900SS from '92 to '97 should fit. Part no. is 0670.38.720 I didn't realise that the 750 Paso cable was shorter. I guess it's because it doesn't have to clear the radiator and has more direct route.[/quote] Awesome, and thanks again Derek (and all that responded) for taking the time and posting the part number. That is the part number I was given, it's for a 1997 900ss, I'll order it later today from my local Ducati dealer. Oh, I did try to repair my cable with solder, then epoxy. No way in hell. You gotta replace it.............
