| paso 750 brake light switches http://ducatipaso.org/forum/viewtopic.php?f=4&t=6106 |
| Author: | Yoric [ Thu May 30, 2013 1:48 pm ] |
| Post subject: | paso 750 brake light switches |
Need to buy a front brake light switch (mine's missing) as well as a rear brake light switch (takes a lot of foot pressure to operate). Please let me know if you have any for sale or where I can source them here in the US if possible. Since this is a safety issue, I'm anxious to install them. I would prefer original, but if I cannot find them, then, ANY replacements will do, including slight modifications. I cannot ride without brake lights and the weather in Colorado is just right!! I look forward to any and offers or advice. TIA Ric |
| Author: | 907pasonut [ Thu May 30, 2013 3:02 pm ] |
| Post subject: | Re: paso 750 brake light switches |
hi Ric, on the 907 (yours might be the same, brembo unit) the front switch is a common microswitch any electronic shop will have one, its held on by two small bolts/screws, remove old switch and match it with new, some new microswitches have 3 terminals, cut one terminal off and 'Bob's your uncle!' didn't realize your switch is missing, I have one right here...I can take a photo and send it cant help you with the rear switch |
| Author: | paso750 [ Thu May 30, 2013 3:03 pm ] |
http://www.giyf.com/ or did your ask your local Duc dealer for availability of those part numbers ? The rear 079654114 is still available. You can also use universal switches like http://www.ebay.com/itm/MOTORCYCLE-HYDR ... 06&vxp=mtr This are NOS front brake light switches (but quite honestly the used one on my bike looks better http://www.ebay.com/itm/Brembo-OEM-brak ... db&vxp=mtr The brake light switches have a M10x1.0 thread btw. Oh, please do add your location in your profile. G. |
| Author: | paso750 [ Thu May 30, 2013 3:08 pm ] |
a microswitch as Claude suggests is even better (#53940041a) |
| Author: | paso750 [ Thu May 30, 2013 3:40 pm ] |
Claude, the 907ie had the microswitch on the brake master pump (which can be fitted also on the 750/906). The 750/906 originally came with a pressure switch instead which sits in the brake line distributer that`s mounted to the lower triple clamp. |
| Author: | Yoric [ Thu May 30, 2013 7:06 pm ] |
thank you all, Claude, yes, if it isn't too much trouble, could you take a couple of close up pics. Mine is completely gone. I have a feeling that whoever installed the Mikunis had to redo the throttle and setup and may have lost/destroyed/misplaced the switch. again, many thanks to all. ric |
| Author: | paso750 [ Thu May 30, 2013 7:14 pm ] |
there never was one |
| Author: | 907pasonut [ Thu May 30, 2013 10:48 pm ] |
this is what the old switch looks like, and the 3 terminal replacement, (just blank or cut the spare terminal) if you have problems finding one I can send you this one...(but look first |
| Author: | higgy [ Thu May 30, 2013 11:14 pm ] |
repeat after me B_E_V_E_L H_E_A_V_E_N |
| Author: | 907pasonut [ Fri May 31, 2013 5:06 am ] |
| Author: | paso750 [ Sat Jun 01, 2013 2:39 pm ] |
I have no clue what they normally cost so there may be cheaper ones than this http://www.ebay.com/itm/DUCATI-750-900- ... 40&vxp=mtr |
| Author: | higgy [ Sat Jun 01, 2013 10:47 pm ] |
I lost the brake junction when I went braided on the brake lines so put a microswitch on the 906. Simple switch over |
| Author: | 907pasonut [ Sun Jun 02, 2013 10:44 am ] |
| Author: | higgy [ Sun Jun 02, 2013 5:19 pm ] |
I'm sure there are cheaper places than Bevel Heaven but I do everything I can to support Steve's efforts at keeping Ducks walking true Ride EM Don't Hide em
