ducatipaso.org • View topic - Barrels, Pistons and Rings from Italspares
It is currently Wed Mar 11, 2026 1:26 pm
 Post subject: Barrels, Pistons and Rings from Italspares
PostPosted: Tue Aug 27, 2013 5:13 am
If you are after a set of Barrels, Pistons and Rings for a 906/907, have a look at:
http://www.ebay.com.au/itm/Ducati-851-9 ... 2a3096b342
Check the postage with Jim or Ian first though! It looks a bit odd...
Cheers.
Nick.
 Post subject: Re: Barrels, Pistons and Rings from Italspares
PostPosted: Tue Aug 27, 2013 9:39 am
PostPosted: Tue Aug 27, 2013 10:27 am
[/quote] I'd be a bit concerned about these pistons though. I've never seen a 4 valve 906/907 before :shock:[/quote]
Hi Derek.
Had a closer look at the picture in the eBay ad. Yeah, I can see what you mean. I purchased a set last month, thought I had better take a closer look. The set I got have the gaps for a 2 valve head in the pistons. I guess its a generic picture?
A 4 valve 907, hmmm...
Cheers.
Nick.
PostPosted: Tue Aug 27, 2013 12:34 pm
hi
i think its a 851/888 big bore kit hence 907 cc
they have 4 valves and no fcolling fins
cheers Joep
