| lockable gas cap in the Netherlands http://ducatipaso.org/forum/viewtopic.php?f=4&t=6419 |
| Author: | paso750 [ Sun Oct 20, 2013 8:40 am ] |
| Post subject: | lockable gas cap in the Netherlands |
http://www.marktplaats.nl/a/motoren/ond ... ousPage=lr it does not fit on the 907ie as the hole diameter is different. |
| Author: | persempre907 [ Sun Oct 20, 2013 7:56 pm ] |
| Post subject: | Re: lockable gas cap in the Netherlands |
| Author: | paso750 [ Mon Oct 21, 2013 7:40 am ] |
really, there are two different ones on the 907ie ? 750/906 outer diameter flange 120 mm hole circle flange 102 mm gascap 76mm 907ie outer diameter flange 120 mm hole circle flange 110 mm gascap ?mm |
| Author: | paso750 [ Fri Jan 17, 2014 6:30 pm ] |
http://www.marktplaats.nl/a/motoren/ond ... ousPage=lr |
| Author: | persempre907 [ Sat Jan 18, 2014 7:44 am ] |
