| Rubber cap hor. cylinder - 906/907 http://ducatipaso.org/forum/viewtopic.php?f=4&t=6627 |
| Author: | duske [ Tue Mar 25, 2014 3:27 pm ] |
| Post subject: | Rubber cap hor. cylinder - 906/907 |
Hi. Can anyone help med with the rubber cover for the belts. It is the one for the horizontal cylinder. Ducati partnumber : 23510061A http://www.stein-dinse.biz/Komplettange ... :8598.html |
| Author: | Mc tool [ Tue Mar 25, 2014 9:54 pm ] |
| Post subject: | Re: Rubber cap hor. cylinder - 906/907 |
I had to rebuild mine as it was cracked around where the screws go in . I would have a look at the later model 2 valve motors , I aint sure ( G probly knows ) but I would think that the later SS motors would have the same piece on them and it may be available under a different part #http://www.oiltalavante.com/DUCATI-23510061A/en . I just had a quick look and this lot have one for 15 euro , I have no idea where they are H |
| Author: | duske [ Wed Mar 26, 2014 7:19 am ] |
Hi. I have a order pending at them, but they are not able to get it. Have also tried Stein Dinze but no luck. I will try to look at the other models to see if they could fit - thanks. |
| Author: | Derek [ Wed Mar 26, 2014 10:56 am ] |
it's the same part on all the 904/944 engines - SS, Monster, ST2 |
| Author: | paso750 [ Wed Mar 26, 2014 11:21 am ] |
actually it`s not http://www.stein-dinse.biz/Komplettange ... tyPhoto/0/ but if that tongue is cut off it probably will be. |
| Author: | duske [ Wed Mar 26, 2014 12:48 pm ] |
I have ordered this and will try a small modification. I will report back if it works... |
| Author: | Derek [ Wed Mar 26, 2014 7:50 pm ] |
