| 906 Paso headlight UK spec wanted http://ducatipaso.org/forum/viewtopic.php?f=4&t=8097 |
| Author: | fueltheburn [ Thu Mar 28, 2019 10:20 pm ] |
| Post subject: | 906 Paso headlight UK spec wanted |
Evening Chaps and Chapess' My first post on here. I am looking for a UK spec headlight for a 906 Paso. I can offer a swap for a Euro spec one if that helps? Cheers Kieran |
| Author: | paso750 [ Fri Mar 29, 2019 8:24 am ] |
| Post subject: | Re: 906 Paso headlight UK spec wanted |
Kieran, you can fit the Koito unit of a Yamaha FZ750. It's a direct replacement and you'll have no problems finding one. G. |
| Author: | Derek [ Fri Mar 29, 2019 9:20 am ] |
What G says : Unfortunately most available are RH dip and some of these old lamps are quite fogged though so try to find a good one. I had to find one for my 907 which came with a European headlight, almost certainly from new. |
| Author: | fueltheburn [ Fri Mar 29, 2019 12:58 pm ] |
Thanks. I did see the FZ 750 lamp as a possible replacement. However most of the ones on there appear to be 1 digit out from the recommended 1985-86 lamp. Can anyone tell me the difference between the 85-86 lamp and the 87-89 one? The 85-86 one has a number of 110-31420 and there are a few on there of the later spec showing 110-31421. Cheers Kieran |
| Author: | paso750 [ Sat Mar 30, 2019 2:34 pm ] |
the 110-31420 is the dual headlight https://www.amazon.co.jp/%E3%83%A4%E3%8 ... B00YIG0FVQ the 110-31421 is the single headlight |
| Author: | fueltheburn [ Sat Mar 30, 2019 6:53 pm ] |
Thanks for the info. Done a deal and hopefully the item that turns up is in good condition. |
