ducatipaso.org :: View topic - 907 ie chain adjuster wanted
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=4&t=8272
Author:  Thebenelliman [ Sun May 17, 2020 5:35 pm ]
Post subject:  907 ie chain adjuster wanted
Does anybody have a chain adjuster I can buy? I went out on my bike today and it has sheared the bolt and lost the gold plate of the adjuster!
Author:  paso750 [ Tue May 19, 2020 7:38 am ]
Post subject:  Re: 907 ie chain adjuster wanted
I don't have one but are you looking for left or right side?
The end plates are the same for the SS/851/888/ and Monster. The bolt is used in the same models plus Multistrada and ST2/3/4.
Author:  Derek [ Tue May 19, 2020 10:34 am ]
Still available from Stein Dinse
Author:  paso750 [ Wed May 20, 2020 10:26 am ]
I wonder why the bolt broke in the first place. I'm guessing it was tightened a bit more after the axle nuts were or the axle came loose (or the conical spacer is installed the wrong way around?!). The bolts are M8x90mm btw.
Since I had read about this also in other forums I lockwired mine. Lockwiring the bolt may have been overdoing it considering the chain has to be checked and readjusted once in a while.
Author:  Thebenelliman [ Wed May 20, 2020 8:21 pm ]
I think the bolt had Metal fatigue and snapped when I accelerated.
Thanks Derek I have ordered the part from Stein Diense!
It was my first ride in 6 months bike is running well glad I spotted the missing adjuster before the wheel could move!
Author:  paso750 [ Sun May 24, 2020 6:22 pm ]
also a solution. :truck: Found on the ducati.ms forum.
Page 1 of 1 All times are UTC
http://www.phpbb.com/
