| The Graduation Gift... http://ducatipaso.org/forum/viewtopic.php?f=8&t=5011 |
Page 1 of 2 |
| Author: | Desmo_Demon [ Thu Aug 18, 2011 2:26 am ] |
| Post subject: | The Graduation Gift... |
I will finish my masters degree in less than two weeks, so I bought myself a graduation gift to celebrate. I just got it yesterday and after only having it for a few hours, it appears to have... Updated master cylinders Carbon fiber bars Keihin FCR 41 carb modification with air box removed "Race" exhaust and a few other small goodies (levers, bar ends, open clutch cover) It's not in too bad of shape with almost 18k miles on it. It's also been repainted. This is just what I've been looking for over the last few years because I wanted one to ride, not simply look at. I'll change the timing belts and do a valve check/adjust on it in the next week or two. Sometime between being at the dealer's (as a consignment) and arriving via transport to me, it decided to drop the spark on the horizontal cylinder. I'll try to determine what is wrong with it over the weekend. |
| Author: | Tamburinifan [ Thu Aug 18, 2011 9:04 am ] |
| Post subject: | Re: The Graduation Gift... |
The perfect gift, congrats! |
| Author: | nnnnnnorman [ Thu Aug 18, 2011 12:12 pm ] |
congradulations! nice machine!
| Author: | persempre907 [ Tue Aug 23, 2011 4:22 pm ] |
Congrats for the degree, but above all for a such wonderful bike Ciao |
| Author: | Desmo_Demon [ Fri Sep 16, 2011 3:40 am ] |
| Author: | paso750 [ Fri Sep 16, 2011 10:31 am ] |
lucky you`ve noticed in time. I`ve seen aftermarket anodized aluminium sprocket nuts also for Ducatis. These had a steel insert though. G. |
| Author: | nnnnnnorman [ Fri Sep 16, 2011 5:20 pm ] |
good job you noticed that before you set out south! enjoy your ride!
| Author: | Desmo_Demon [ Mon Sep 19, 2011 1:13 pm ] |
| Author: | Desmo_Demon [ Mon Sep 26, 2011 4:14 pm ] |
I also noticed that the bike has been stripped down to the bare frame so the frame and swingarm could be repainted or powdercoated. From what I've noticed about the way it was put back together, I have decided to check a bunch of things, so far, the engine mounting bolts were about 1/3 and 1/2 the torque spec. In the near future, I'll probably pull the forks and triple trees off the bike and check/replace the steering head bearings. It has a mild shimmy in the front end, and I'm betting it is the bearings.....Have two front sprockets coming in - which need to be machined to be correct. No one seems to have the correct one available. |
| Author: | Tamburinifan [ Fri Sep 30, 2011 7:00 am ] |
db2 blog w some useful info: http://bimota-db2.blogspot.com/2005_09_01_archive.html I could get you his mail if you want, friend of mine. PM if so. |
| Author: | Desmo_Demon [ Tue Oct 04, 2011 7:33 pm ] |
| Author: | higgy [ Tue Oct 04, 2011 7:57 pm ] |
It was a DB stole my trophy this year at the BBQ, not sure why I was in that group,guess some of us know more than others ![]() and I rode in |
| Author: | Tamburinifan [ Wed Oct 05, 2011 9:36 am ] |
| Author: | paso750 [ Thu Nov 10, 2011 9:52 am ] |
As I don`t really know much about Bimotas I googled the DB2 and according to what I found the front sprocket is the same for the DB2/3/4. Doesn`t seem to be so hard to find one if it`s not a 16 tooth sprocket. 14 and 15 I found. I`ve read in one forum that the front sprocket of the Cagiva Canyon 900ie would be the same. http://www.jtsprockets.com/52.0.html?&L ... id=3236&p= edit: which may not be correct as it seems the DB2 has a 520 chain and the Canyon a 525. One parts dealer here in Germany is: http://www.bimota-parts.de/ Parts catalogues are here if you don`t have them already: (go to "parts & accessories") http://bimotadealer.bimotaamerica.com/d ... ex_us.html The service and owner`s manual: http://www.v2enthusiast.de/files/1-manu ... anual.html http://www.v2enthusiast.de/files/1-manu ... nual-.html G. |
| Author: | Desmo_Demon [ Mon Nov 14, 2011 2:20 am ] |
