ducatipaso.org • View topic - Stainless Steel Fairing Bolts
It is currently Tue Sep 30, 2025 7:48 am
 Post subject: Stainless Steel Fairing Bolts
PostPosted: Sun Nov 12, 2006 9:28 pm
I was thinking of removing all the black fairing bolts and replacing them with stainless steel bolts. I think there are two different sizes, 6mm and 8mm. Anyone know any source or kits for these?
Thanks,
Tim
PostPosted: Mon Nov 13, 2006 6:44 pm
I also am replacing the fairing fixing.
So, I bought the rubber nuts from the local dealer, but any bolt.
The rubber harden, so you've to replace them to avoid the fairing cracks.
You can use the stock bolts, there not harden!
If you want steel bolts, you can brush the black ones....
PostPosted: Mon Nov 13, 2006 7:06 pm
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Mon Nov 13, 2006 10:08 pm
PostPosted: Mon Nov 13, 2006 10:20 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Tue Nov 14, 2006 11:42 am
I don't think it's the weight, the wind load at speed would be the far bigger factor. I converted the OEM panels on my '92 900ss to Dzus, very heavy and thick panels, and they were fine. Until I forgot to attach them together at the bottom while at Indianapolis Raceway Park, and the left side came off at about 120mph! It doesn't come off pretty, and wow did it travel! Left the racetrack altogether, came down outside in a parking lot..... And yes, I fixed and re-used it!
If you're concerned about thickness, Lockhart Phillips USA sells their own version of Dzus in different lengths, for OEM or aftermarket race bodywork. (sorry, shameless sponsor plug here!)
PostPosted: Tue Nov 14, 2006 5:44 pm
 Post subject: fairing bolts
PostPosted: Tue Nov 14, 2006 8:25 pm
PostPosted: Wed Nov 15, 2006 3:39 pm
PostPosted: Wed Nov 15, 2006 10:45 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Nov 16, 2006 11:13 am
PostPosted: Thu Nov 16, 2006 9:57 pm
Users browsing this forum: No registered users and 132 guests
