ducatipaso.org • View topic - Paso exhaust noise level
It is currently Mon Jun 22, 2026 10:11 am
 Post subject: Paso exhaust noise level
PostPosted: Sat Nov 18, 2006 7:27 pm
PostPosted: Sat Nov 18, 2006 7:48 pm
PostPosted: Sun Nov 19, 2006 6:48 am
PostPosted: Sun Nov 19, 2006 11:45 am
PostPosted: Sun Nov 19, 2006 3:35 pm
PostPosted: Sun Nov 19, 2006 4:11 pm
PostPosted: Thu Dec 07, 2006 6:31 am
Just after purchasing new in 1988, I fitted the pipes & mufflers from the Limited model. After installing a K&N low restriction filter and re-jetting, it ran (and still runs) great, sounded much better, yet is not too loud--quite mellow actually, as I didn't adopt the larger valves of the Limited model.
The diameter of pipes and outlets is significantly larger, but keep in mind the mufflers are plainly marked for track use only. The thing I like about them, if you can find a set, is they look stock (except of course for the outlet diameter).
[/img]
Make it a good day,
Sheldon
'88 Paso
'62 200 GT
'78 Laverda 3CL Jarama
'84 Laverda RGS 1000
Users browsing this forum: No registered users and 36 guests
