ducatipaso.org • View topic - Started Looking at My Paso Project Bike
It is currently Sun Mar 01, 2026 2:22 am
Post new topic Reply to topic  [ 139 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 10  Next
PostPosted: Mon Nov 06, 2006 1:14 pm
I FINALLY added another page for the project....
Page Five - http://www.desmodemon.com/paso_project_4.html
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
PostPosted: Mon Nov 27, 2006 2:53 pm
For those following this project of mine....
Page 6 - http://www.desmodemon.com/paso_project_5.html
I think I have a lead on an upper triple clamp.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Thu Nov 30, 2006 10:13 pm
PostPosted: Fri Dec 01, 2006 8:29 am
PostPosted: Fri Dec 01, 2006 2:12 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Fri Dec 01, 2006 11:15 pm
PostPosted: Mon Dec 04, 2006 2:55 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Mon Jan 29, 2007 8:13 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Tue Jan 30, 2007 3:28 pm
Here's an update that I did last night....
http://www.desmodemon.com/paso_project_6.html
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Wed Mar 21, 2007 12:35 pm
This is taking longer than I was expecting, initially......
Here's Page 8 of the series - http://www.desmodemon.com/paso_project_7.html
At least the front end is back on the bike....FINALLY!
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Tue Apr 03, 2007 2:07 am
PostPosted: Tue Apr 03, 2007 1:12 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Fri Apr 06, 2007 7:52 pm
Hey Desmo,
as you`re in process of rebuilding the bike`s front end which I`m currently also doing, did you have a large metal disc below the ring nut ? From inside out the parts catalogue lists the washer, the bearing, the distance piece with the O-ring in it, the seal and the ring nut. On my bike there`s one more disc which is not listed. Like the ring nut it`s slightely larger in diameter as the frame. I`ll try to make a pic tomorrow.
The second question is about the lower roller bearing. As normal when one removes the triple clamps the lower bearing remains on the steering axle. I cannot get the bearing from the axle though. It`s not rusted or so, in fact it looks very good ans is nicely greased. Very strange. In fact on my complete spare fork it`s no problem to move the bottom roller bearing up and down on the steering axle although that one is in bad shape. Any idea ?
Last question is about washers. The parts catalogue shows washers for the bolts of the front lower frame rails and the bolt of the engine mount. Those were not on my bike. I`m not even sure if they are necessary as these bolts are the large headed type with the grabbing egdes on the head`s bottom.
Do you have washers under these bolts ?
PS: it would be great if your site would also have a "back" button
PostPosted: Fri Apr 06, 2007 9:06 pm
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
PostPosted: Sat Apr 07, 2007 10:26 am
