ducatipaso.org • View topic - Parts Interchange
It is currently Sun May 03, 2026 6:46 pm
 Post subject: Parts Interchange
PostPosted: Thu Dec 14, 2006 5:13 pm
PostPosted: Fri Dec 15, 2006 1:11 pm
PostPosted: Fri Dec 15, 2006 3:13 pm
PostPosted: Fri Dec 15, 2006 5:03 pm
PostPosted: Fri Dec 15, 2006 8:46 pm
PostPosted: Fri Dec 15, 2006 9:16 pm
PostPosted: Fri Dec 15, 2006 9:32 pm
PostPosted: Mon Dec 18, 2006 4:46 am
Another kick stand on Ebay if you still need one.
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
PostPosted: Mon Dec 18, 2006 9:32 am
I'd buy it.
No matter, the frames are the same, except for the front side (radiator and headlamp subframe) so you can fit it for sure.
PostPosted: Mon Dec 18, 2006 2:28 pm
Btw, those side stands are made from alumium, so if U know some aluminium welder, he can "reweld" it to suitable, like i did to mine for Conti pipes. It brake easily, if U try to bent it by own tools. ST series have steel side stand. :thumbup:
PostPosted: Thu Jan 18, 2007 8:09 pm
From what's been said above, does that infer that early monster swinging arms fit 907's. Also is there anything else that fits ?
cheers
Mike
PostPosted: Thu Jan 18, 2007 8:57 pm
Hi Mike
Give Baines Racing a call - I think they may have a swingarm knocking around - whats happened to yours by the way ?
could someone like Spondon repair or " re dress" it?
PostPosted: Fri Jan 19, 2007 9:51 am
the chain went, locked round the back wheel and took great chunks out of the swinging arm, after it had smashed a few of the plastics on route.
cheers
Mike
PostPosted: Sat Jan 20, 2007 9:22 am
:mad: :mad: :mad: :mad: :mad: :mad:
I hope you are fine :thumbup: .
Has the swingarm only dents or is it bent?
If there are only dents you can fill up with the aluminium.
You have also to do a metal casting and then you will take off the excess and will brush it.
It will look as new :thumbup: :thumbup: :thumbup:
Users browsing this forum: No registered users and 28 guests
