ducatipaso.org • View topic - Foam insert in oil vapor return line
It is currently Mon Jun 22, 2026 11:30 am
 Post subject: Foam insert in oil vapor return line
PostPosted: Wed Dec 20, 2006 5:35 pm
PostPosted: Wed Dec 20, 2006 9:20 pm
PostPosted: Thu Dec 21, 2006 10:35 pm
PostPosted: Fri Dec 22, 2006 3:44 pm
PostPosted: Tue Jan 02, 2007 5:58 pm
Also in my Paso the pipe breathes directly into the air. Here in Italy it's illegal because of pollution restrictions, but I had no choice with air filters and no airobox...
I placed my pipe on the left side of the bike:
Indeed, I don't like all that oil leaking from the pipe to the rear chain/wheel. Did anyone try a better placement?
I know that on Monsters someone connects an air filter directly to the valve from engine, but this solution is dangerous because if the filter gets dirty, oil overpressure may occur.
A better solution is to place an alluminium can, as in racing bikes. Here is an handmade solution for Monsters:
So... what did you do on yuor Paso?
LC
PostPosted: Tue Jan 02, 2007 7:01 pm
PostPosted: Tue Jan 02, 2007 11:44 pm
I've used these in the past. Mounted the stud to the tab where the rear part of the fuel tank mounts. Oil always has a chance to flow back to engine cause it is almost straight up. Not sure what diameter it was but they make it in 3/4" and 1" o.d. pipe :thumbup:
It is made for crankcase ventilation.
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
PostPosted: Wed Jan 03, 2007 8:31 pm
________________________
Christian
Paso 750
Monster 900 carbu
999s 2005 Xerox
http://www.zattol.com/perso
PostPosted: Wed Jan 03, 2007 11:30 pm
PostPosted: Thu Jan 04, 2007 3:24 am
Tim
Port Murray, NJ
1999 Ducati 996
1998 ST2
2000 Honda RC51
PostPosted: Thu Jan 04, 2007 7:20 pm
Christian
Paso 750
Monster 900 carbu
999s 2005 Xerox
PostPosted: Fri Jan 05, 2007 9:56 am
did you remove the black plastic box that originally was connected to the cranckase and to the airbox? (the "mistery box" of )
LC
PostPosted: Fri Jan 05, 2007 8:25 pm
Yes, I had remove the black box.
I not have the original air box filter, I have a special K&N filter directly mounted on carb to give a maximum air of motor !
Christian
Paso 750
Monster 900 carbu
999s 2005 Xerox
PostPosted: Tue Jan 09, 2007 1:00 pm
