ducatipaso.org • View topic - MYSTERY BOX???
It is currently Thu Mar 05, 2026 8:48 pm
 Post subject: MYSTERY BOX???
PostPosted: Fri Jan 05, 2007 5:57 am
PostPosted: Fri Jan 05, 2007 9:05 am
PostPosted: Fri Jan 05, 2007 4:53 pm
When I took mine out the bolt and nut had seized. Being that the nut was captured or kind of heat welded into the plastic tank, it required prying the nut/bolt upward and prying the box downward to get them apart. It can now be repaired with a wellnut, if I ever want to return it to use.
PostPosted: Fri Jan 05, 2007 5:13 pm
Everyone removes this box when they convert to individual carbs like Mikunis or Dellortos. Because there is no longer a way to pipe it into the stock airbox which is no longer used. You can install the little black box back if you wish or you can install a crankcase breather filter directly on the hose from the engine.
check out this thread
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
 Post subject: Thank you!
PostPosted: Sun Jan 07, 2007 7:47 pm
PostPosted: Mon Jan 08, 2007 2:40 am
Look here for some info on body panel fasteners. :thumbup:
Tim
Port Murray, NJ
1999 Ducati 996
1998 ST2
2000 Honda RC51
 Post subject: Fasteners
PostPosted: Mon Jan 08, 2007 4:23 am
Thanks Tim.
I'll look into that.
Pasophist
