ducatipaso.org • View topic - POd filter
It is currently Wed Oct 01, 2025 5:32 pm
 Post subject: POd filter
PostPosted: Fri Jan 05, 2007 3:02 pm
year: 1985
After the mikuni upgrade i want to buy 2 pod filter,but i don't know the exact measurment that they have to do,i bought two sport filter from an auto tuning shop,but they are too big :sad:
i don't lose money but now i have to order two filter in these shop....
Help requred :confused: :confused: :confused:
PostPosted: Fri Jan 05, 2007 4:26 pm
I have K&N filters on my Paso but that is with Dellorto carbs. Here is a link to the K&N site with info on these filters. You will have to measure the inlet outer diameter and match them up.
http://tinyurl.com/ylabds
 Post subject: UNI-filtre
PostPosted: Fri Jan 05, 2007 5:47 pm
UNI-filtre should be good. I will be mounting a pair these i think.
http://www.repairmanual.com/items/70
Regards
Klaus
PostPosted: Fri Jan 05, 2007 6:59 pm
Klaus, WHITCH of those modell fits to Mikunis??? I dont have yet Mikunis(maybe soon), only 40mm Dellortos fitted and Webers(in garrage shelves)... But i must think future also... :evil:
 Post subject: POD 57 mm.
PostPosted: Fri Jan 05, 2007 7:44 pm
If you are mounting direct to the mikuni, the 57 mm. will fit. But I am not sure of the clearens inside the tank. I am making a swep above the mikuni some thing like on the picture belowe.
http://www.motorcykelgalleri.dk/html/ga ... sp?ID=1846
See last picture. It is not from my PASO but the others are.
Regards
Klaus
PostPosted: Fri Jan 05, 2007 8:51 pm
So, from WHERE are coming those white air intake manifolds to fit filters? Looks, that it can function well with pod filters and seems, that enough small system to fit under Paso tank... :thumbup: Btw, is It You, Klaus in that one foto sitting in Paso? Not so bad! :thumbup:
PostPosted: Fri Jan 05, 2007 9:02 pm
sweeps look like PVC plastic piping. 180 degree bends.
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
PostPosted: Fri Jan 05, 2007 10:14 pm
Hey there ducapiero,
Foam pods work just fine as long as the diameter is correct. I used Unifilter pods for the Mikunis, type PK79, refer to http://www.unifilter.com.au for more details.
Fraser.
PostPosted: Sat Jan 06, 2007 1:09 pm
year: 1985
thanks a lot guys for all your replies....
i 'll give you soon some development... :cool:
Users browsing this forum: No registered users and 57 guests
